查看: 5510|回复: 4
[求助]magma安装求助
发表于 2005-8-14 18:03:54 | 显示全部楼层 |阅读模式
最近在redhat linux 企业版上安装了magma软件,但是在启动时出现如下错误,不知道怎样解决
Copyright (C) 1997-2005 Magma Design Automation Inc.
mantle version 4.2.53-linux24_x86 (compiled Jan 27 2005 00:36:35)
LIC-1    Setting default *** file to '/boot/edasoft/magma/common/ *** '.
LIC-12   The following features have been checked out: BLAST_VIEW BLAST_WRAP
        BLAST_SPEED BLAST_BUILDER BLAST_PLAN BLAST_PLANPRO BLAST_CREATE
        BLAST_RTL BLAST_LOGIC BLAST_FUSION_APX BLAST_SI BLAST_RAIL RGEN
        BLAST_TEST
SIG-1    Mantle process caught a fatal exception
        Details:
        Process with PID=3715 executing
        /boot/edasoft/magma/linux24_x86/bin/mantle
        caught signal=11 (Segmentation fault)
        code=1: Signal was generated by kernel.
        Additional info: address not mapped to object
        Faulting addr=0x4fba34c
        end-of-stack=0xbf82a7e4
        Memory usage:
               overall peak reserved=1319900
               currently reserved=1319900
        Free swap space=1052220
checkpoint NOT rolled backSegmentation fault (core dumped)
请大侠指点,多谢
发表于 2005-8-15 15:02:17 | 显示全部楼层
[求助]magma安装求助
估计是内存太小了吧?
楼主机器的内存多少?
发表于 2010-1-13 13:21:31 | 显示全部楼层
发表于 2011-10-14 00:23:18 | 显示全部楼层
Thank u very much guys....
发表于 2013-9-5 19:33:51 | 显示全部楼层
楼主能否分享一下license?
GMT+8, 2025-12-19 15:12 , Processed in 1.959057 second(s), 5 queries , Gzip On, Redis On.
