楼主: 山水一色
ESD中文资料
发表于 2011-1-17 23:46:52 | 显示全部楼层
The NPN BJT clamp has a 3 V CMOS driver with an NPN base directly connected
to the inverter output (Fig. 5.6a, b). Each clamp has an NPN with a total
emitter width of 540 μm. The RC-timer time constant is ∼6 μs.
The clamp provides an appropriate low leakage in the powering sequence
(Fig. 5.6e) and the desired single pulse waveform (Fig. 5.6c) with a low clamping
voltage, if the number of slave clamps is sufficiently high (Fig. 5.6c). The peak
amplitude of the waveform produced by the circuit is below 1 V and practically does
not change starting with ∼10 clamps (Fig. 5.6c). However, the voltage accumulation
effect is observed in the case of a multiple zap sequence through the I/O diodes
(Fig. 5.6d).
发表于 2011-1-17 23:51:47 | 显示全部楼层
感謝大大分享這個可貴的 資料
发表于 2011-1-17 23:54:10 | 显示全部楼层
very good!!!
发表于 2011-1-18 09:46:29 | 显示全部楼层
回复 1# 山水一色
    好多东西啊,能不能压缩一下,少要几个信元呢?
发表于 2011-1-18 09:47:51 | 显示全部楼层
回复 1# 山水一色
发表于 2011-1-18 09:50:39 | 显示全部楼层
回复 1# 山水一色
    没有钱了阿!
发表于 2011-1-18 09:53:18 | 显示全部楼层
回复 1# 山水一色
    继续拿信元。
发表于 2011-1-18 09:54:36 | 显示全部楼层
回复 1# 山水一色
    打工赚钱。
发表于 2011-1-18 09:55:47 | 显示全部楼层
回复 1# 山水一色
    打工!!
发表于 2011-1-18 09:57:21 | 显示全部楼层
回复 1# 山水一色
    受不了了,我也把压箱底的东西拿来卖了。
GMT+8, 2025-12-27 15:28 , Processed in 0.018113 second(s), 3 queries , Gzip On, Redis On.
