查看: 4868|回复: 1
求助与讨论:LAN91c111网卡芯片的调试 [对网卡or调试、有经验or感兴趣的朋友请进来!]
发表于 2009-8-21 17:07:25 | 显示全部楼层 |阅读模式
求助与讨论:LAN91c111网卡芯片的调试 [对网卡or调试、有经验or感兴趣的朋友请进来!]我在Nios II7.2中跑Simple Socket Server软件例子,控制台提示:
Your Ethernet MAC address is 00:07:ed:ff:cb:c8
prepared 1 interface, initializing...
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
smsc91c111 Auto-negotiation: 100 Mbps, Full Duplex
SMSC ethernet Rev: 0x3392, ram: 8192
IP address of et1 : 0.0.0.0         //在调试思路I中变为192.168.1.234
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
注意:网口的LINK和ACT指示灯正常,板子DIY的!
  -SOPC Builder:
    LAN91C111 Interface - named "lan91c111"
    Flash Memory (CFI) - named "ext_flash"
  -System Library settings:
    RTOS Type - MicroC/OS-II
    Software Component - NicheStack TCP/IP Stack - Nios II Edition
    Period System Timer - SYS_CLK_TIMER
近一个月了还没搞定它
请各位帮忙,原理图可提供
http://www.fpga-design.net/viewthread.php?tid=2522&extra=page%3D1
发表于 2013-1-22 20:49:25 | 显示全部楼层
高手啊  我们最近准备反向做91c111  到时有问题要请教你啊
GMT+8, 2025-11-3 03:43 , Processed in 0.017538 second(s), 7 queries , Gzip On, Redis On.
