查看: 6870|回复: 27
DIGITAL COMPENSATION OF ERRORS AT THE FRONT-END OF ADCS
发表于 2009-8-19 20:40:54 | 显示全部楼层 |阅读模式
Chapter 1 Introduction ..............................................................................................1
1.1 Motivation ..................................................................................................1
1.2 Organization ...............................................................................................4
Chapter 2 Nonlinearity at the ADC’s Front-End....................................................7
2.1 Analog-to-Digital Converters .....................................................................7
2.2 Overview of ADC linearity limitations ....................................................10
2.3 Nonlinearity at the acquisition stage ........................................................14
2.3.1 Input dependent charge injection......................................................14
2.3.2 Nonlinearity in the tracking phase....................................................22
2.3.3 Modeling tracking nonlinearity ........................................................25
2.4 Nonlinearity in the input circuit ...............................................................26
2.4.1 Input circuit including transformer...................................................28
2.4.2 Input circuit including amplifier.......................................................33
2.5 Summary...................................................................................................34
xi
Chapter 3 Digital Correction of Dynamic Nonlinearities .....................................37
3.1 Dynamic error correction using look-up tables ........................................38
3.2 Modeling nonlinear systems with memory using Volterra series ............40
3.3 Proposed digital algorithm .......................................................................41
3.3.1 Digital Correction using linear modeling of the derivative..............42
3.3.1.1 Evaluation of the model: Random noise input…………………44
3.3.1.2 Evaluation of the model: Sinewave input……………………...48
3.3.2 Digital correction using interpolation...............................................50
3.3.2.1 How to do the interpolation?.......................................................51
3.3.2.2 Evaluation of the model………………………………………..52
3.3.3 Nonlinearity correction on a multi-tone input signal .......................56
3.3.4 Algorithm performance in presence of noise ...................................58
3.3.5 Algorithm performance in presence of other circuit non-idealities..59
3.4 Summary...................................................................................................62
Chapter 4 Experimental Results .............................................................................65
4.1 ADC test setup..........................................................................................66
4.2 Implementation of the digital post processing..........................................67
4.2.1 Digital correction scheme.................................................................67
4.2.2 Coefficient calibration ......................................................................69
4.3 Measurement results .................................................................................70
4.3.1 Robustness of the algorithm with temperature variations ................72
4.3.1.1 Analysis of the impact of temperature variation on dynamic
nonlinearity.......................................................................................................73
4.3.2 General applicability of the algorithm..............................................75
xii
4.3.3 Algorithm performance on different input driving circuits ..............76
4.4 Summary...................................................................................................79
Chapter 5 Impact of Substrate Noise on the Performance of High-Speed ADCs
.....................................................................................................................................81
5.1 ADC architecture......................................................................................82
5.2 Analysis of the impact of substrate noise on flash ADCs ........................84
5.3 Experimental setup ...................................................................................87
5.4 Measurement results .................................................................................89
5.5 Summary...................................................................................................92
Chapter 6 Conclusion...............................................................................................93
6.1 Summary...................................................................................................93
6.2 Suggestions for future work .....................................................................95
DIGITAL COMPENSATION OF ERRORS AT THE FRONT-END OF ADCS.pdf
2.5 MB, 下载次数: 179 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-8-20 23:15:29 | 显示全部楼层
发表于 2009-8-28 00:57:29 | 显示全部楼层
very good material
very good material
发表于 2009-8-29 00:13:49 | 显示全部楼层
:victory: :victory:
发表于 2009-8-29 03:49:55 | 显示全部楼层
发表于 2009-9-5 12:12:04 | 显示全部楼层
thanks for sharing
发表于 2010-1-30 00:32:05 | 显示全部楼层
thanks
发表于 2010-1-31 11:33:47 | 显示全部楼层
have a look
发表于 2010-1-31 15:58:50 | 显示全部楼层
ding ding
发表于 2011-8-14 10:23:10 | 显示全部楼层
ggggggggggggggggggggggggg0d
GMT+8, 2025-12-18 00:39 , Processed in 0.025442 second(s), 6 queries , Gzip On, Redis On.
