查看: 2755|回复: 8
verilog基础问题
发表于 2009-8-16 11:14:00 | 显示全部楼层 |阅读模式
-1=-32‘d1=32'hFFFFFFFF 麻烦解释下,谢谢啦!
 楼主| 发表于 2009-8-16 22:14:28 | 显示全部楼层
没人吗?
发表于 2009-8-17 00:08:14 | 显示全部楼层
it's 2's complement
say +1 is 0000_0000_0000_0000_0000_0000_0000_0001 in binary
in 1's complement, then it's simply invert it:
1111_1111_1111_1111_1111_1111_1111_1110
But this kind of negative number has a problem, there're 2 zeros, namely 0 and ffff_ffff in hex.
Therefore, they've invent something called 2's complement.
it's 1's complement + 1, i.e.
-1 in 1's complement + 1, => 0xffff_fffe + 1 = 0xffff_ffff.
What's nice about 2's complement is e.g. 1 + -1 = 0x0000_0001 + 0xffff_ffff = 0!!!!
 楼主| 发表于 2009-8-17 08:56:18 | 显示全部楼层
thanks
发表于 2009-8-17 10:34:08 | 显示全部楼层
补码,
但是这个是有符号数,也就是32位最多只能表示  -2^31 ~ (2^31-1),注意,超过这个范围的就不要再和这个数做运算了,除非扩位
发表于 2009-8-17 18:05:48 | 显示全部楼层
先看看
发表于 2009-8-19 14:59:57 | 显示全部楼层
since int is 32 bit in verilog, -1 is express as complimentary code in verilog, that's why 32'hFFFFFFFF
发表于 2009-8-19 20:13:36 | 显示全部楼层
理解了~,谢谢
发表于 2009-8-22 21:12:53 | 显示全部楼层
不同進位的問題
GMT+8, 2025-12-26 04:56 , Processed in 0.023474 second(s), 7 queries , Gzip On, Redis On.
