楼主: 要你命3000
IUS82 & Encounter81 patch(更新)
发表于 2009-8-6 23:00:13 | 显示全部楼层
eetop thanks
eetop thanks
发表于 2009-8-7 00:39:08 | 显示全部楼层
您好主席先生,可以ü上传ius82再次感谢。
发表于 2009-8-7 07:29:19 | 显示全部楼层
thanks a lot
thanks a lot....
发表于 2009-8-7 09:38:28 | 显示全部楼层
LZ太强悍了  PF
发表于 2009-8-7 12:06:16 | 显示全部楼层
这个一定要置顶,永不沉落!
发表于 2009-8-7 14:51:58 | 显示全部楼层
太好了...終於找到了
发表于 2009-8-7 17:31:00 | 显示全部楼层
试一下,没过。
SERVER xxxmen ANY 5290
DAEMON cdslmd /eda/cds/ius82/tools/bin/cdslmd
#SERVER B2000 ANY 5280
#DAEMON cdslmd your_path/cdslmd
FEATURE 100 cdslmd 1000.0000 permanent uncounted HOSTID=ANY SIGN2=565094150FE7469F
FEATURE 111 cdslmd 1000.0000 permanent uncounted HOSTID=ANY SIGN2=594D921110E9459B
启动:/eda/cds/ius82/tools/bin/lmgrd -c xxx.dat
报错如下:
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "xilComposerFE" with code "E480FE64EDA9A9". Ignored.
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "xilConceptFE" with code "D2548219732035". Ignored.
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "xilEdif" with code "ED8C9123FD0C917". Ignored.
CADENCE_ERROR_MSG:       Your license file is corrupted. No licenses will be served. You will need to restart the license server after addressing the problem. Please contact Cadence support at support@cadence.com for further assistance.
16:36:53 (cdslmd) Cannot open license file cds8_lic.dat
16:36:53 (cdslmd) EXITING DUE TO SIGNAL 52
16:36:54 (lmgrd) cdslmd exited with status 52 (No license file)
16:36:54 (lmgrd) Please correct problem and restart daemons
启动license 失败。
请LZ帮忙看一下,问题出在哪?
谢谢!
 楼主| 发表于 2009-8-7 17:36:49 | 显示全部楼层
原帖由 thelastone 于 2009-8-7 17:31 发表
试一下,没过。
FEATURE 100 cdslmd 1000.0000 permanent uncounted HOST ...
不要用server方式,用node-lock。
不用起daemon
发表于 2009-8-7 18:01:51 | 显示全部楼层
试用ncverilog时候爆的问题:
ncverilog myadd.v
ncverilog: 08.20-p001: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
Trying to check out license...
        Incisive_HDL_Simulator 8.2 - Failed
        NC_Verilog_Simulator 8.2 - Failed
        Affirma_NC_Simulator 8.2 - Failed
        Incisive_Design_Team_Simulator 8.2 - Failed
        Incisive_Enterprise_Simulator 8.2 - Failed
ncsim: *F,NOLICN: Unable to checkout license for the simulation. (flag - 2) 'lic_error -18'.
发表于 2009-8-7 18:06:46 | 显示全部楼层
setenv CDS_LIC_FILE xxx.dat
ncverilog myadd.v
Loading snapshot worklib.myadd:v .................... Done
ncsim> source /eda/cds/ius82/tools/inca/files/ncsimrc
ncsim> run
ncsim: *W,RNQUIE: Simulation is complete.
ncsim> exit
成功了,谢谢LZ老大
GMT+8, 2025-12-12 13:45 , Processed in 0.269660 second(s), 3 queries , Gzip On, Redis On.
