查看: 6049|回复: 4
ISE6。1(FPGA)综合时出现。这三个WARNING是什么意思??会不会影响稳定性??
发表于 2004-6-4 11:55:59 | 显示全部楼层 |阅读模式
WARNING:Xst:819 - E:/XC2S15XY/XC2S15(3)1/xc2s/XC2S151.vhd line 141: The following signals are missing in the process sensitivity list:
INFO:Xst:1304 - Contents of register <I<12>> in unit <xc2s151> never changes during circuit operation. The register is replaced by logic。
WARNING:Xst:1710 - FF/Latch  <Mtridata_I_0> (without init value) is constant in block <xc2s151>.
 楼主| 发表于 2004-6-4 15:58:12 | 显示全部楼层
我除了编程是自己干,其他的都由ISE自动完成,这样会不会出问题,不稳定???
发表于 2004-6-4 19:36:22 | 显示全部楼层
1、一些信号没有放在你的敏感表内,这是你的书写语法问题,找到这些信号加入敏感列表。
2、有一个register I<12>从来没有变,你需要查看一下不变是否影响你的结果。
3、需要根据你的具体设计分析。
 楼主| 发表于 2004-6-5 09:57:39 | 显示全部楼层
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity XC2S15 is
Port (
CP  :  IN STD_LOGIC ;  --CLK
A    : IN STD_LOGIC_VECTOR(10 DOWNTO 0); --A0-A10 ADD  ISA总线的11位地址线
IOR : IN STD_LOGIC ; --Read Signal
IOW : IN STD_LOGIC ; --Writ Signal
AEN : IN STD_LOGIC ; --Add Free
        IO16 : OUT STD_LOGIC; --16IO
CP5:OUT STD_LOGIC;--
PLUSE: OUT STD_LOGIC;
I: INOUT STD_LOGIC_VECTOR(15 DOWNTO 0)   --D0-D15
end XC2S15;
architecture Behavioral of XC2S15 is
SIGNAL BUF2:STD_LOGIC_VECTOR (15 DOWNTO 0);
SIGNAL Y7,Y8,Y9:STD_LOGIC;
SIGNAL ADD    : STD_LOGIC_VECTOR (13 DOWNTO 0); --ADD+IOR+IOW+AED
SIGNAL OUTPUT : STD_LOGIC_VECTOR (4 DOWNTO 0); --OUTPUT CONECL
SIGNAL BUFX2: STD_LOGIC_VECTOR (13 DOWNTO 0);
SIGNAL STAGESBUF:STD_LOGIC_VECTOR (13 DOWNTO 0);
SIGNAL ORDER:STD_LOGIC_VECTOR (13 DOWNTO 0);
SIGNAL QN :STD_LOGIC_VECTOR (3 DOWNTO 0);
SIGNAL CP1,CP2,CP4,RST:STD_LOGIC;
SIGNAL COUNTER :STD_LOGIC_VECTOR (15 DOWNTO 0);
SIGNAL DLY :STD_LOGIC;
SIGNAL SINX:STD_LOGIC;
SIGNAL XAXA:STD_LOGIC;
begin
       ADD(13)<=A(10); --  \
ADD(12)<=A(9);  --   |
ADD(11)<=A(8);  --   |
ADD(10)<=A(7);  --   |
ADD(9)<=A(6);   --   |
ADD(8)<=A(5);   --   |
ADD(7)<=A(4);   --    > ADD
ADD(6)<=A(3);   --   |
ADD(5)<=A(2);   --   |
ADD(4)<=A(1);   --   |
ADD(3)<=A(0);   --   |
ADD(2)<=IOR;   --   |
ADD(1)<=IOW;   --   |
ADD(0)<=AEN; --  /
    OUTPUT<="00010" WHEN ADD="01100000000010" ELSE --0X300     --read BUFX status
    "00100" WHEN ADD="01100000010100" ELSE --0X302      --write stages
    "01000" WHEN ADD="01100001010100" ELSE --0X30A
            "00001" ;
   Y9<=OUTPUT(3);    --写脉冲数
   Y8<=OUTPUT(2);    --写分频数
   Y7<=OUTPUT(1);    --读状态
   IO16<=OUTPUT(0);  --ISA总线16位数据选择信号,0有效
PROCESS(Y7)
BEGIN
   IF  Y7='1' THEN--BUF2为BUFX2空与满的标志,I是ISA16位数据总线
        I<=BUF2;
    ELSE
I<="ZZZZZZZZZZZZZZZZ";
    END IF;
END PROCESS;
PROCESS(Y9,CP2,CP)
  VARIABLE BUFX2 :STD_LOGIC_VECTOR(15 DOWNTO 0);
BEGIN
   IF  Y9='1' THEN   --写脉冲数BUFX2减一次,XAXA翻转一次,BUFX2减两次,PLUSE输出一个脉冲
        BUFY2:=I;
   ELSIF BUFX2/="0000000000000000" THEN
           IF CP2' EVENT AND CP2='1' THEN       --根据任意分频数分出的频率CP2进行
              BUFX2:=BUFX2-1;
   XAXA<=NOT XAXA;
  END IF;
      SINX<='1';
   ELSE
      SINX<='0';
   END IF;
   IF BUFX2="0000000000000000" THEN
      BUF2<="1010101010101010";
   ELSE
      BUF2<="0000000000000000";
   END IF;
END PROCESS;
PROCESS(Y8)
BEGIN
   IF  Y8='1' THEN
        STAGESBUF<=I;
    END IF;
END PROCESS;
PROCESS(CP,RST)      --10分频    CP=10M   CP1=1M
BEGIN
  IF RST='1'THEN
QN<="0000";
ELSIF CP' EVENT AND CP='1' THEN
QN<=QN+1;
END IF;
END PROCESS;
  RST<='1' WHEN QN=10 ELSE
'0';
  CP1<=QN(2);
PROCESS(CP1)                       --根据STAGESBUF任意分频  CP2=CP1 * (STAGESBUF/32767)
BEGIN
  IF CP1' EVENT AND CP1='1' THEN
          DLY<=COUNTER(15);
          COUNTER<=COUNTER+STAGESBUF;
       END IF;
  CP2<=(COUNTER(15) XOR DLY) AND NOT CP1;
  CP5<=CP1;
  END PROCESS;
  PLUSE<=XAXA WHEN SINY='1' ELSE    --PLUSE为输出的脉冲
'0';
end Behavioral;
通过ISA总线读0X300,假如为0XAAAA,表示BUFX2为空,通过0X302写入STAGESBUF,通过0X30A写入BUFX2
就可以看到PLUSE输出口有以CP2的频率输出BUFX2/2个等宽脉冲。
我每次以2K的频率来读0X300,频率不高,我的CP被自动指定为全局时钟,我用IBUFG+BUFG。
运行一次或几百次都没有问题,但连续运行几个小时就要出现脉冲数不准的现相。没有规律,不知道是为什么
我用ISE6.1  进行综合、布线,有没有问题???是不是因为XST的综合出问题??
发表于 2004-6-29 13:12:52 | 显示全部楼层
怎样得到ISE 6.1 .我的Email lixiang19830822@163.com QQ:280567840.谢谢
GMT+8, 2025-12-26 13:25 , Processed in 0.030047 second(s), 8 queries , Gzip On, Redis On.
