查看: 3899|回复: 7
发一个UCB的DC-DC博士论文
发表于 2009-7-13 16:43:26 | 显示全部楼层 |阅读模式
有兴趣的看看
tonyPhD.pdf
2.02 MB, 下载次数: 65 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-7-13 17:53:31 | 显示全部楼层
thank you much!
发表于 2009-7-14 01:13:51 | 显示全部楼层
题目不说清楚,有骗钱嫌疑
Abstract
High-Efficiency Low-Voltage DC-DC Conversion for Portable
Applications
by
Anthony John Stratakos
Doctor of Philosophy in Engineering-Electrical Engineering
and Computer Sciences
University of California, Berkeley
Professor Robert W. Brodersen, Chair
Motivated by emerging portable applications that demand ultra-low-power
hardware to maximize battery run-time, high-efficiency low-voltage DC-DC conversion
is presented as a key low-power enabler. Recent innovations in low-power digital
CMOS design have assumed that the supply voltage is a free variable and can be set to
any arbitrarily low level with little penalty. This thesis introduces and demonstrates an
array of DC-DC converter design techniques which make this assumption more viable.
The primary design challenges to high-efficiency low-voltage DC-DC
converters are summarized. Design techniques at the power delivery system, individual
control system, and circuit levels are described which help meet the stringent
requirements imposed by the portable environment. Design equations and closed-form
expressions for losses are presented. Special design considerations for the key dynamic
voltage scaling enabler, called the dynamic DC-DC converter are given. The focus
throughout is on low-power portable applications, where small size, low cost, and high
energy efficiency are the primary design objectives.
The design and measured results are reported on three prototype DC-DC
converters which successfully demonstrate the design techniques of this thesis and the
low-power enabling capabilities of DC-DC converters in portable applications. Voltage
scaling for low-power throughput-constrained digital signal processing is reviewed and
is shown to provide up to an order of magnitude power reduction compared to existing
3.3 V standards when enabled by high-efficiency low-voltage DC-DC conversion. A
new ultra-low-swing I/O strategy, enabled by an ultra-low-voltage and low-power DCDC
converter, is used to reduce the power of high-speed inter-chip communication by
greater than two orders of magnitude. Dynamic voltage scaling is proposed to
dynamically trade general-purpose processor throughput for energy-efficiency, yielding
up to an order of magnitude improvement in the average energy per operation of the
processor. This is made possible by a new class of voltage converter, called the dynamic
DC-DC converter, whose primary performance objectives and design considerations are
introduced in this thesis.
High-efficiency low-voltage DC-DC conversion for portable applications - tonyPhD.pdf
2.02 MB, 下载次数: 37 , 下载积分: 资产 -2 信元, 下载支出 2 信元
High-efficiency low-voltage DC-DC conversion for portable applications.pdf
发表于 2009-7-14 07:35:43 | 显示全部楼层
感謝....有人出來說明...thanks~
发表于 2009-7-14 08:15:36 | 显示全部楼层
:victory: :victory:
发表于 2009-9-5 13:10:25 | 显示全部楼层
thank you very much!
发表于 2016-6-19 16:17:28 | 显示全部楼层
THANK YOU
发表于 2020-6-26 01:51:56 | 显示全部楼层
谢谢
GMT+8, 2025-12-18 14:26 , Processed in 0.215064 second(s), 9 queries , Gzip On, Redis On.
