查看: 4042|回复: 1
A Robust Digital Baseband Predistorter ConstructedUsing Memory Polynomials
发表于 2009-6-30 15:30:31 | 显示全部楼层 |阅读模式
Abstract—Power amplifiers (PAs) are inherently nonlinear
devices and are used in virtually all communications systems.
Digital baseband predistortion is a highly cost-effective way
to linearize PAs, but most existing architectures assume that
the PA has a memoryless nonlinearity. For wider bandwidth
applications such as wideband code-division multiple access
(WCDMA) or wideband orthogonal frequency-division multiplexing
(W-OFDM), PA memory effects can no longer be ignored,
and memoryless predistortion has limited effectiveness. In this
paper, instead of focusing on a particular PA model and building
a corresponding predistorter, we focus directly on the predistorter
structure. In particular, we propose a memory polynomial model
for the predistorter and implement it using an indirect learning
architecture. Linearization performance is demonstrated on a
three-carrier WCDMA signal.
A+robust+digital+baseband__+predistorter+constructed+using+memory+polynomials.pdf
247.81 KB, 下载次数: 48 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-7-2 09:00:59 | 显示全部楼层
thanks
GMT+8, 2025-12-25 19:34 , Processed in 0.020107 second(s), 7 queries , Gzip On, Redis On.
