查看: 11543|回复: 49
火热出炉JSSC 2009 07 全集
发表于 2009-6-29 10:07:05 | 显示全部楼层 |阅读模式
1、A 70 pJ/Pulse Analog Front-End in 130 nm CMOS for UWB Impulse Radio Receivers
2、A Short Range, Low Data Rate, 7.2 GHz-7.7 GHz FM-UWB Receiver Front-End
3、A 25 dBm Digitally Modulated CMOS Power Amplifier for WCDMA/EDGE/OFDM With Adaptive Digital Predistortion and Efficient Power Control
4、A Low-Power CMOS SAW-Less Quad Band WCDMA/HSPA/HSPA+/1X/EGPRS Transmitter
5、A Low-Power Digital DLL-Based Clock Generator in Open-Loop Mode
6、A Robust High Speed Serial PHY Architecture With Feed-Forward Correction Clock and Data Recovery
7、A 5.75 to 44 Gb/s Quarter Rate CDR With Data Rate Selection in 90 nm Bulk CMOS
8、A Low-Complexity, Low-Phase-Noise, Low-Voltage Phase-Aligned Ring Oscillator in 90 nm Digital CMOS
9、Design and Analysis of a 90 nm mm-Wave Oscillator Using Inductive-Division LC Tank
10、Noise Reduction in CMOS Circuits Through Switched Gate and Forward Substrate Bias
11、A 0.65 THz Focal-Plane Array in a Quarter-Micron CMOS Process Technology
12、Single-Photon Synchronous Detection
13、A 66 $mu$ W 86 ppm$/^{circ}$ C Fully-Integrated 6 MHz Wienbridge Oscillator With a 172 dB Phase Noise FOM
14、A Low-Voltage Mobility-Based Frequency Reference for Crystal-Less ULP Radios
15、A 12-bit 3.125 MHz Bandwidth 0–3 MASH Delta-Sigma Modulator
16、An 8-Bit Flash Analog-to-Digital Converter in Standard CMOS Technology Functional From 4.2 K to 300 K
17、A Temperature-to-Digital Converter Based on an Optimized Electrothermal Filter
18、A 36 V Programmable Instrumentation Amplifier With Sub-20 $mu$V Offset and a CMRR in Excess of 120 dB at All Gain Settings
19、A 300 nW, 15 ppm/$^{circ}$C, 20 ppm/V CMOS Voltage Reference Circuit Consisting of Subthreshold MOSFETs
20、Low-Power 32-bit Dual-MAC 120 $mu$W/MHz 1.0 V icyflex1 DSP/MCU Core
21、A 3.6 pJ/Access 480 MHz, 128 kb On-Chip SRAM With 850 MHz Boost Mode in 90 nm CMOS With Tunable Sense Amplifiers
JSSC2009.07.part1.rar
4.88 MB, 下载次数: 215 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.07.part2.rar
4.88 MB, 下载次数: 224 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.07.part3.rar
4.88 MB, 下载次数: 212 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.07.part4.rar
4.88 MB, 下载次数: 218 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.07.part5.rar
4.88 MB, 下载次数: 208 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.07.part6.rar
4.88 MB, 下载次数: 206 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.07.part7.rar
1.37 MB, 下载次数: 211 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-6-29 13:22:43 | 显示全部楼层
good materials, thanks!
发表于 2009-6-29 16:13:21 | 显示全部楼层
收集了,谢谢!
发表于 2009-6-30 22:52:11 | 显示全部楼层
KANKANKANKAN
发表于 2009-6-30 23:47:50 | 显示全部楼层
very well
发表于 2009-6-30 23:50:07 | 显示全部楼层
收集了,谢谢!
发表于 2009-6-30 23:54:49 | 显示全部楼层
发表于 2009-7-1 07:25:27 | 显示全部楼层
thanks for share!
发表于 2009-7-1 07:39:14 | 显示全部楼层
thanks for your share!
发表于 2009-7-2 12:20:31 | 显示全部楼层
Thanks for sharing
GMT+8, 2025-12-18 02:28 , Processed in 0.030828 second(s), 7 queries , Gzip On, Redis On.
