查看: 6824|回复: 3
破解linux下quartus9的方法
发表于 2009-6-23 10:01:47 | 显示全部楼层 |阅读模式
cd <quartus_install_dir>/linux
cp libsys_cpt.so libsys_cpt.so.bak
then run gdb:
gdb> file libsys_cpt.so
gdb> info function l_pubkey_verify
Note the resulting address (for Quartus 7.2 it was 0x000c617b)
quit gdb, then open libsys_cpt.so using a hex editor, then go to the address
that you got from gdb and replace the 3 bytes starting at that address with
those bytes: 31 C0 C3
Alternatively one can get the address of 'l_pubkey_verify' function using the
command:
nm libsys_cpt.so | grep l_pubkey_verify
Now regular quartus tool flow can work, except for the Design Space Explorer,
to get the Design Space Explorer working do the following:
* Note the first few bytes (8 or more) in the 'l_pubkey_verify' function of the
original libsys_cpt.so, and search for those bytes in quartus_sh (using a hex
editor). I found that the number of bytes to search for (which were 8 for
Quartus 8.0) are the minimum number of bytes which will match only once in
quartus_sh.
* Replace the first 3 bytes with those bytes: 31 C0 C3
发表于 2009-8-13 18:26:26 | 显示全部楼层
谢谢,正要安装了
发表于 2010-5-31 22:50:04 | 显示全部楼层
Thanks for the information!!!
发表于 2010-6-17 11:04:31 | 显示全部楼层
原来是这样啊
GMT+8, 2025-12-19 13:24 , Processed in 0.017002 second(s), 5 queries , Gzip On, Redis On.
