查看: 5441|回复: 7
需要一片ieee论文,谢谢Improved Switched Tuning of Differential CMOS VCOs
发表于 2009-6-5 11:49:48 | 显示全部楼层 |阅读模式
http://ieeexplore.ieee.org/Xplore/login.jsp?url=http%3A%2F%2Fieeexplore.ieee.org%2Fiel5%2F82%2F22044%2F01025154.pdf%3Farnumber%3D1025154&authDecision=-203
Improved switched tuning of differential CMOS VCOs
Sjoland, H.
Circuits and Systems II: Analog and Digital Signal Processing, IEEE Transactions on
Volume 49, Issue 5, May 2002 Page(s): 352 - 355
Digital Object Identifier   10.1109/TCSII.2002.801415
Summary: Varactors for continuous frequency tuning are typically used in LC-oscillators. However, they have some drawbacks for large tuning ranges, such as high tuning sensitivity causing high sensitivity to noise and disturbances on the control voltage. Furthermore, large metal-oxide-semiconductor (MOS) varactors have high conversion of harmless amplitude noise into harmful phase noise. To reduce these problems a small varactor can be used in combination with MOS-transistors that switch fixed capacitors in and out of the oscillator. The limitations due to the imperfect complementary metal-oxide-semiconductor (CMOS) switches are investigated, and an improved structure for use with the popular differential CMOS LC-oscillator is presented.
 楼主| 发表于 2009-6-5 16:43:09 | 显示全部楼层
请方便下载的好友上传一下。谢谢!
发表于 2009-6-5 16:52:58 | 显示全部楼层
我也贡献一次
improved Switched Tuning of Differential CMOS VCOs.pdf
77.49 KB, 下载次数: 97 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-4-22 20:37:34 | 显示全部楼层
thanks for sharing
发表于 2011-5-4 19:06:54 | 显示全部楼层
thanks for sharing
发表于 2011-5-27 14:54:37 | 显示全部楼层
我也正好需要,沾这位兄弟的光了
发表于 2012-1-16 16:59:55 | 显示全部楼层
THANSK
发表于 2012-3-30 19:56:33 | 显示全部楼层
看看!!
GMT+8, 2025-12-22 12:51 , Processed in 0.022064 second(s), 7 queries , Gzip On, Redis On.
