1. A Class-E PA With Pulse-Width and Pulse-Position Modulation in 65 nm CMOS
2. An Energy-Efficient All-Digital UWB Transmitter Employing Dual Capacitively-Coupled Pulse-Shaping Drivers
3. A V-Band CMOS VCO With an Admittance-Transforming Cross-Coupled Pair
4. A 100 MS/s 4 MHz Bandwidth 70 dB SNR Delta-Sigma ADC in 90 nm CMOS
5. A 35-GS/s, 4-Bit Flash ADC With Active Data and Clock Distribution Trees
6. A Low-Power Baseband ASIC for an Energy-Collection IR-UWB Receiver
7. Design of Three-Stage Class-AB 16ohm Headphone Driver Capable of Handling Wide Range of Load Capacitance
8. All-Digital Ring-Oscillator-Based Macro for Sensing Dynamic Supply Noise Waveform
9. Reduction of Inductive Crosstalk Using Quadrupole Inductors
10. On-Chip Supply Noise Regulation Using a Low-Power Digital Switched Decoupling Capacitor Circuit
11. Radiation Tolerance Techniques for a 1.6 Gb/s, 8 K and 4 K Low-Density Parity-Check Encoder
12. A Voltage Scalable 0.26 V, 64 kb 8T SRAM With Vmin Lowering Techniques and Deep Sleep Mode
13. An Efficiency-Enhanced CMOS Rectifier With Unbalanced-Biased Comparators for Transcutaneous-Powered
High-Current Implants
14. A Spectral-Scanning Nuclear Magnetic Resonance Imaging (MRI) Transceiver
15. A Bio-Inspired Active Radio-Frequency Silicon Cochlea
16. Focal-Plane Algorithmically-Multiplying CMOS Computational Image Sensor |
