查看: 1265|回复: 0
siwave里面进行安全检查的时候第一项的错误!导致不能仿真!如何解决?
发表于 2009-5-27 17:47:57 | 显示全部楼层 |阅读模式
PCB 文件是PADS导出的asc文件
通过ansoflinks4.1转换的!!
Detected: net "AGND" has a plane which self-intersects on the layer Top.
Detected: net "AGND" has a plane with a void which self-intersects on the layer Top.
Detected: net "AGND" has a plane which self-intersects on the layer Bottom.
Detected: net "AGND" has a plane with a void which self-intersects on the layer Bottom.
GMT+8, 2025-12-21 13:02 , Processed in 0.012907 second(s), 3 queries , Gzip On, Redis On.
