查看: 16716|回复: 14
用Flashprogrammer往44B0X板上烧录程序出现问题
发表于 2006-2-28 17:32:19 | 显示全部楼层 |阅读模式
我单位买了一套优龙的44B0X开发板!为了我们设计产品的需要,我凭自己的理解按照开发板的模式(主板+核心板)DIY了一套开发环境,可是当我用Flashprogrammer往44B0X核心板上烧录程序出现问题,所有的按键都提示:“Target Communications Error: Unable to put Target into Background Mode”,当我用arm的代理软件检测时,提示:“检测到:ARM7TDMI”!
我用Fluted 烧录时虽然擦除和写都提示成功,但是校验时都不正确!DOS下的提示如下:
E:\arm\debug\FLUTED>f2k
E:\arm\debug\FLUTED>AllowIo FluteD.exe  /a a -f FS44B0II_BIOS.bin -v -s 0
AllowIO for PortTalk V2.0
Copyright 2002 Craig Peacock
http://www.beyondlogic.org
Granting exclusive access to all I/O Ports
Executing FluteD.exe a -f FS44B0II_BIOS.bin -v -s 0 with a ProcessID of 2124
PortTalk Device Driver has set IOPM for ProcessID 2124.
E:\arm\debug\FLUTED>Flash Programming Tool via IEEE1149.1 BSR (Version 0.8a)
Designed By David Geng  April, 2000
FCD File:./default.fcd          Data File:FS44B0II_BIOS.bin
[Setup FCD File]
[Setup Scan Chain]
Parse BSDL file s3c44b0x.bsd ... OK
[Setup Flash Pin Map]
[Setup JTAG Port]
[Check Device ID]
Get ID Register ... ID Code Correct 0x1F0F0F0F
Start From: 0 (0x0)
End Before: 37448 (0x9248)
Total Byte: 37448 (0x9248)
[Erase]
OK
[Write]
59%
Verify missed at 18721 (0x4921) + 0 Original:0x37 JTAG:0xFF
Verify missed at 18721 (0x4921) + 1 Original:0x8A JTAG:0xFF
Verify missed at 18722 (0x4922) + 0 Original:0x7C JTAG:0xFF
Verify missed at 18722 (0x4922) + 1 Original:0xC JTAG:0xFF
Verify missed at 18723 (0x4923) + 0 Original:0x20 JTAG:0xFF
Verify missed at 18723 (0x4923) + 1 Original:0x0 JTAG:0xFF
Verify missed at 18725 (0x4925) + 0 Original:0x0 JTAG:0xFF
Verify missed at 18725 (0x4925) + 1 Original:0x0 JTAG:0xFF
OK
>>> SUCCESS <<<
对了,还有一个哥们说是存储芯片的问题,我用的是:SST 39VF160 70-4C-EK
                                      他说让我换:SST 39VF1601 70-4C-EK
是这样吗?我很迷惑!谢谢指点!
如果不是,我应该怎么办??
 楼主| 发表于 2006-3-2 16:16:50 | 显示全部楼层
大家好!虽然没有人回复,但是有人在看我也比较高兴!烧录我好像已经过了,但是不运行程序怎么回事呢??
我将DEFAULT.FCD文件中的延时参数改大后,用用Fluted 烧录时擦除和写还有校验现在都提示成功了,但是里面的代码不运行!用Flashprogrammer还是原来的错误!我用示波器检测32.768k的晶振没有输出,但是10m的晶振输出正常!现在的问题会是什么故障造成的!对了,sclk也有输出,我不知道是否正确!希望版主给个提示!
发表于 2006-4-25 10:20:24 | 显示全部楼层
支持一下LZ。去年心血来潮,买了一块44b0的板子,不过还没有动过,只是试用了一下 ,没有好好 研究过,回去看看LZ的问题。呵呵大家一起学习。
发表于 2006-7-9 20:54:40 | 显示全部楼层
我现在也碰到了跟楼主一样的问题:用fluted烧写校验时出错,程序不运行;用flashpgm也显示:“Target Communications Error: Unable to put Target into Background Mode”。不知道这个问题楼主解决的怎么样了?急等!谢谢了!
发表于 2006-7-9 23:24:23 | 显示全部楼层
建议用flashpgm2.1.8试试,我试了很多的版本,这个好用!
发表于 2006-7-10 09:16:01 | 显示全部楼层
好的,我先试试看
发表于 2006-7-10 10:15:37 | 显示全部楼层
还是一样的情况;另外刚焊好的裸板上电的时候,几个LED或亮或灭,按复位键指示灯状态不变,而且不闪烁,难道是CPU的问题?
发表于 2006-7-10 10:38:36 | 显示全部楼层
另外有一点,由于使用的NOR FLASH是39VF800A,所以用FLASHPGM的时候,我也进行了相应的设置;换用FLUTED烧写二进制文件时,也对文件DEFAULT.FCD作了修改,修改后如下:
[Chain]
Device=s3c44b0x.bsd
[Read]
BeginByte=0
EndByte=0x3ff
[Flash] ; SST39VF800
WriteCmd=0x5555, 0xaa, 0x2aaa, 0x55, 0x5555, 0xa0
EraseCmd=0x5555, 0xaa, 0x2aaa, 0x55, 0x5555, 0x80, 0x5555, 0xaa, 0x2aaa, 0x55, 0x0, 0x30
EraseDelay=25
Block=0x800, 64
AddrWidth=19
DataWidth=2
BigEndian=0
A0=3
A1=2
A2=1
A3=160
A4=159
A5=158
A6=157
A7=156
A8=155
A9=154
A10=153
A11=151
A12=150
A13=149
A14=148
A15=147
A16=146
A17=145
A18=144
D0=136
D1=135
D2=134
D3=133
D4=132
D5=131
D6=130
D7=129
D8=128
D9=127
D10=124
D11=123
D12=122
D13=121
D14=120
D15=119
WR=16
RD=15
CS=17
ResetCtrl=0x00
High=
Low=
SafeMode=1
这时烧写bios文件没有问题,但是烧自己改的程序时总是在校验时出错。请问到底是什么原因呢?谢谢!
发表于 2006-7-10 10:56:07 | 显示全部楼层
一般程序有装载地址和运行地址之分,一般启动的boot程序,会从装载地址把程序搬移到运行地址,在将PC指针,指向程序的运行地址.
我以前用过flashpgm,里面有设置烧录地址(装载地址)的选项,不知道是否设置正确.
发表于 2006-7-10 11:13:36 | 显示全部楼层
那这个应该怎么设置呢?我是按照一个开发板的使用手册来操作的,上边没有这方面的说明。
设置完以后我的界面上几个分栏是这样的:Target RAM Starts at:0x0c000000
Starts at:0x00000000   Width:16 *1,这个需要修改吗?
GMT+8, 2025-12-19 22:15 , Processed in 0.022186 second(s), 9 queries , Gzip On, Redis On.
