查看: 3100|回复: 5
about token
发表于 2004-5-7 20:02:34 | 显示全部楼层 |阅读模式
[这个贴子最后由wilson在 2004/05/07 08:04pm 第 1 次编辑]
hi,buddies, may i ask what does "token" mean by the Code Compression and Decompression?
Thanks a lot!
 楼主| 发表于 2004-5-9 21:31:48 | 显示全部楼层
about token
nobody knows?
发表于 2004-5-10 09:33:41 | 显示全部楼层
about token
通信上叫“令牌”,在码压缩解压缩上特别是MPEG上也起标志作用的。有了token,已经压缩或解压缩的码流才可以送出,属于起流控制作用的。
 楼主| 发表于 2004-5-10 16:08:34 | 显示全部楼层
about token
thank u! Otherwise your signiture is very cool.
发表于 2004-5-10 16:32:53 | 显示全部楼层
about token
That is the lyric of "where did you sleep last night", Narvana's song.
发表于 2004-5-10 16:42:57 | 显示全部楼层
about token
我还以为是。。。。。。
GMT+8, 2025-12-25 00:25 , Processed in 0.024040 second(s), 8 queries , Gzip On, Redis On.
