查看: 2925|回复: 0
请问:modelsim 和verilog-xl有什么大的差别么?
发表于 2004-5-5 11:54:40 | 显示全部楼层 |阅读模式
近来在做pre_layout时序仿真时,发现一个问题:同样的库文件,同样的testbench文件
,同样的SDF文件,利用modelsim仿真没有报告任何错误信息,而在工作站上用verilog-xl仿真
则报告很多错误。哪位对这两个软件都很了解么?下面的这些错误信息如何去解释?谢了先
maxx.sdf  maxx.sdf  L18462: SDFA Error: Unable to find source port test_maxxtime.MAXX.db1d[0]
          maxx.sdf  L18463: SDFA Error: Unable to find source port test_maxxtime.MAXX.db2d[0]
          maxx.sdf  L18464: SDFA Error: Unable to find source port test_maxxtime.MAXX.db1d[1]
          maxx.sdf  L18465: SDFA Error: Unable to find source port test_maxxtime.MAXX.db2d[1]
          maxx.sdf  L18466: SDFA Error: Unable to find source port test_maxxtime.MAXX.db1d[2]
          maxx.sdf  L18467: SDFA Error: Unable to find source port test_maxxtime.MAXX.db2d[2]
          maxx.sdf  L19161: SDFA Warning: Negative timing check limit -0.240000 set to 0
          maxx.sdf  L19162: SDFA Warning: Negative timing check limit -0.310000 set to 0
          maxx.sdf  L19165: SDFA Warning: Negative timing check limit -0.390000 set to 0
          maxx.sdf  L19166: SDFA Warning: Negative timing check limit -0.420000 set to 0
          maxx.sdf  L19171: SDFA Warning: Negative timing check limit -0.500000 set to 0
          maxx.sdf  L19172: SDFA Warning: Negative timing check limit -0.350000 set to 0
GMT+8, 2025-12-26 15:15 , Processed in 0.016500 second(s), 7 queries , Gzip On, Redis On.
