查看: 7662|回复: 11
SILVACO软件对光二级挂名的计算机模拟
发表于 2009-5-13 13:44:27 | 显示全部楼层 |阅读模式
go atlas
title LED simulation
# Simulates a simple LED device
# SILVACO International 1992, 1993, 1994, 1995, 2001
# SECTION 1: MESH GENERATION
# 4 um X 4 um
mesh space.mult=1.0
x.mesh l=0.0  spacing=0.25
x.mesh l=1.5  spacing=0.1
x.mesh l=2.5  spacing=0.1
x.mesh l=4.0  spacing=0.25
y.mesh l=0.0  spacing=0.1
y.mesh l=0.5  spacing=0.002
y.mesh l=0.75 spacing=0.05
y.mesh l=1.0  spacing=0.002
y.mesh l=1.1  spacing=0.002
y.mesh l=1.35 spacing=0.05
y.mesh l=1.6  spacing=0.002
y.mesh l=4.0  spacing=0.5
eliminate y.direction x.min=0.0 x.max=4.0 y.min=3.0 y.max=4.0
# SECTION 2: REGIONS AND ELECTRODES
# (graded heterojunctions outside of cladding layers)
region num=1 Material=GaAs   y.max=0.5
region num=2 Material=AlGaAs y.min=0.5 y.max=1.0 x.comp=0.35
# grad.12=0.1
region num=3 Material=GaAs   y.min=1.0 y.max=1.1
region num=4 Material=GaAs   y.min=1.6
region num=5 Material=AlGaAs y.min=1.1 y.max=1.6 x.comp=0.35
# grad.34=0.1
elec       num=1  name=anode x.min=1.5 x.max=2.5 y.min=0.0 y.max=0.0
elec       num=2  name=cathode bot
# SECTION 3: DOPING PROFILES
doping conc=5.0e18 p.type x.left=1.5 x.right=2.5 gaus char=0.5 ratio.lat=0.6
doping uniform region=1 p.type conc=1.e15
doping uniform region=2 p.type conc=1.e15
doping uniform region=3 p.type conc=1.e15
doping uniform region=4 n.type conc=2.e18
doping uniform region=5 n.type conc=2.e18
# SECTION 4: MATERIAL MODELS
# (radiative recombination constants same for AlGaAs and GaAs )
material copt=1.5e-10
material material=GaAs mun=6500 taurel.el=1.e-12 taumob.el=1.e-12 vsat=1.e7
material material=AlGaAs mun=2000 taurel.el=1.e-12 taumob.el=1.e-12 align=0.6
model auger optr srh bgn print
# If barrier exists at anode need to set workf=4.07+barrier height
#contact  name=anode workfun=4.07
# SECTION 5: OUTPUT FLAGS
output con.band val.band recomb u.srh u.aug u.rad flowlines
# SECTION 6: INITIAL SOLUTION
# no carriers
solve init
# SECTION 7: BIAS RAMP
probe name="Recombination" recombination integrate \
      left=0 right=4 top=1.0 bottom=1.1
probe name="Radiative" radiative integrate \
# 0.0 to 2.0 V forward bias
log outf=optoex06.log master
method newton climit=1e-4 maxtrap=10
solve  l.wave=0.8 vanode=0.0 vstep=0.025 vfinal=2.0 name=anode
save outfile=optoex06.str
# structure plot
tonyplot optoex06.str -set optoex06_0.set
# radiative recombination rate contours
tonyplot  optoex06.str -set optoex06_1.set
# luminous intensity vs bias
tonyplot optoex06.log -set optoex06_2.set
# SECTION 8: EXTRACTION
# Extract total and radiative components of recombination
# (can be used to calculate luminous efficiency)
measure u.total
measure u.radiative
quit
桌面.rar
26.09 KB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
OrCAD电子教程.rar
1.43 MB, 下载次数: 39 , 下载积分: 资产 -2 信元, 下载支出 2 信元
PSpice_training.pdf
651.87 KB, 下载次数: 22 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-8-13 21:09:22 | 显示全部楼层
66
Thanks for sharing .................dink dink !!!
发表于 2009-8-13 21:11:06 | 显示全部楼层
55
发表于 2010-3-22 20:49:59 | 显示全部楼层
thanks
发表于 2010-12-20 10:53:48 | 显示全部楼层
觉得其中有几个不足的地方
发表于 2011-1-16 18:25:14 | 显示全部楼层
谢谢分享
发表于 2011-1-16 20:47:40 | 显示全部楼层
thanks, thanks and thanks.
发表于 2011-1-21 21:31:45 | 显示全部楼层
多谢,我想下载看看
发表于 2011-2-16 22:47:32 | 显示全部楼层
值得一看的资料,先下了再说
发表于 2011-6-6 17:57:28 | 显示全部楼层
初来咋到
GMT+8, 2025-12-14 19:57 , Processed in 0.021848 second(s), 7 queries , Gzip On, Redis On.
