楼主: chibijia
tt ff ss snfp和fnsp各代表什么工艺模型
发表于 2011-7-15 13:07:14 | 显示全部楼层
thnak  you
发表于 2011-7-20 16:12:41 | 显示全部楼层
不错,学习了。
发表于 2012-12-28 11:18:32 | 显示全部楼层
学习了 嗯 谢谢
发表于 2012-12-28 11:34:33 | 显示全部楼层
Types of cornersOne naming convention for process corners is to use two-letter designators, where the first letter refers to the N-channel MOSFET (NMOS) corner, and the second letter refers to the P channel (PMOS) corner. In this naming convention, three corners exist: typical, fast and slow. Fast and slow corners exhibit carrier mobilities that are higher and lower than normal, respectively. For example, a corner designated as FS denotes fast NFETs and slow PFETs.
There are therefore five possible corners: typical-typical (TT) (not really a corner of an n vs. p mobility graph, but called a corner, anyway), fast-fast (FF), slow-slow (SS), fast-slow (FS), and slow-fast (SF). The first three corners (TT, FF, SS) are called even corners, because both types of devices are affected evenly, and generally do not adversely affect the logical correctness of the circuit. The resulting devices can function at slower or faster clock frequencies, and are often binned as such. The last two corners (FS, SF) are called "skewed" corners, and are cause for concern. This is because one type of FET will switch much faster than the other, and this form of imbalanced switching can cause one edge of the output to have much less slew than the other edge. Latching devices may then record incorrect values in the logic chain.
In addition to the FETs themselves, there are more on-chip variation (OCV) effects that manifest themselves at smaller technology nodes. These include process, voltage and temperature (PVT) variation effects on on-chip interconnect, as well as via structures.
摘自wiki
发表于 2012-12-28 11:35:56 | 显示全部楼层
FF and SS 不是指的电流的大小 指的是Carrier mobility  希望大家注意
发表于 2013-5-6 15:23:21 | 显示全部楼层
好多好帖子,我喜欢
发表于 2013-5-8 14:26:58 | 显示全部楼层
2楼正解
发表于 2014-3-25 10:40:46 | 显示全部楼层
知道了,详细讲解
发表于 2014-3-25 21:34:53 | 显示全部楼层
少了溫度的選項,~~~
发表于 2015-2-4 10:46:03 | 显示全部楼层
回复 15# haipiao
   说的对
GMT+8, 2025-12-29 11:13 , Processed in 0.020058 second(s), 6 queries , Gzip On, Redis On.
