查看: 5526|回复: 2
IO power pad and core power pad connect
发表于 2009-5-7 15:05:48 | 显示全部楼层 |阅读模式
My
IO
and
Core
power
pad
in
the
reference
library
is
IO
power
pad
cell;
PLVDDH
IO
ground
pad
cell
PLVSSH
Core
power
pad
cell
PLVDDC
Core
ground
pad
cell
PLVSSC
and
I
want
to
connect
Core
power
pad
to
global
net
VDD
connect
Core
ground
pad
to
global
net
GND
connect
IO
power
pad
to
global
net
VDDH
connect
IO
ground
pad
to
global
net
VSSH
In pre-placement optimization,there some warnings as follow:
cannot connect PF automatically,
Multiple PG nets dound for voltage areas
there are 2 power nets for voltage area DEFAULT_VA
there are 2 ground netd for voltage area DEFAULT_VA
after routing
during LVS there are some ERRORs such as net VDD,GND,VSSH,VDDH are floating.
what can I do to deal with these problems.
 楼主| 发表于 2009-5-7 15:08:54 | 显示全部楼层
My IO and Core power pad in the reference library is:
IO power pad cell&#65306LVDDH
IO ground pad cell: PLVSSH
Core power pad cell: PLVDDC
Core ground pad cell: PLVSSC
and I want to:
connect Core power pad to global net VDD
connect Core ground pad to global net GND
connect IO power pad to global net VDDH
connect IO ground pad to global net VSSH
after routing
头像被屏蔽
发表于 2010-4-18 02:04:02 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-28 14:04 , Processed in 0.013073 second(s), 3 queries , Gzip On, Redis On.
