楼主: wiwi111
Laker32v3p6_crack
发表于 2009-11-2 18:42:41 | 显示全部楼层
可以 work 嗎?
发表于 2009-11-2 18:50:13 | 显示全部楼层
我已经下载安装,比32V3版本好用
发表于 2009-11-3 10:54:57 | 显示全部楼层
希望这不会跑出ERROR
发表于 2009-11-3 13:48:01 | 显示全部楼层
檔案好多喔!!不知道如何才能完全下載!!
发表于 2009-11-9 11:27:47 | 显示全部楼层
这个版本还是会出现error吧!
发表于 2009-11-10 20:11:57 | 显示全部楼层
thanks
发表于 2009-11-11 22:31:29 | 显示全部楼层
會 down  嗎  ?
有些 crack 過會 down
請用過  發表一下
发表于 2009-11-23 13:42:40 | 显示全部楼层
68# alcohol
會 down
*ERROR* License Error: 0x41a, Contact customer support. Program will now exit.
#0  0x00bfc228 in read () from /lib/i686/libc.so.6
#1  0x00c68ff4 in ?? () from /lib/i686/libc.so.6
#2  0x00ba1ef9 in _IO_file_read_internal () from /lib/i686/libc.so.6
#3  0x00ba0cae in _IO_new_file_underflow () from /lib/i686/libc.so.6
#4  0x00ba31ab in _IO_default_uflow_internal () from /lib/i686/libc.so.6
#5  0x00ba2f9d in __uflow () from /lib/i686/libc.so.6
#6  0x00b980e0 in _IO_getline_info_internal () from /lib/i686/libc.so.6
#7  0x00b9801f in _IO_getline_internal () from /lib/i686/libc.so.6
#8  0x00b96f26 in fgets () from /lib/i686/libc.so.6
#9  0x0a97071b in _sys_fgets ()
#10 0x0a9497dd in sysGetCallStack ()
#11 0x0a94a441 in exit ()
#12 0x0a951c5b in sysExit ()
#13 0x0a94a7a7 in sysErrorVaList ()
#14 0x0a94a7c2 in sysError ()
#15 0x0a7cb341 in snsLicServerHeartBeat ()
#16 0x0a7c8a11 in sc_igetStatus ()
#17 0x0a7c8ae6 in sc_getStatus ()
#18 0x0a81f95b in toolLicCmdGetStatus ()
#19 0x0a811e56 in cmdiMapFunc ()
#20 0x0a811ee5 in cmdMapFunc ()
#21 0x0a349c8d in wtiKeyPressed ()
#22 0x0a349d24 in wtiKeyPressedCB ()
#23 0x0a55fd18 in XtDispatchEventToWidget ()
#24 0x0a5606fd in _XtDefaultDispatcher ()
#25 0x0a5608b0 in XtDispatchEvent ()
#26 0x0a345261 in wtMainLoop ()
#27 0x0804ee75 in App_C::MsgDispatch ()
#28 0x08050178 in LEOApp_C::MsgDispatch ()
#29 0x080534b0 in main ()
Process exit with status code of 1
Above call-stack dumped because process called exit with a value other than 0
For debugging purposes. No coredump signal raised.
[1]    Exit 1                        /pub/eda/bak/laker32v3p6_bak/Laker32/bin/laker
53.243u 10.214s 2:26:24.74 0.7% 0+0k 0+0io 275pf+0w
发表于 2009-12-1 13:57:50 | 显示全部楼层
檔案好多喔!!不知道可不可以全部下載!!???
試看看!!
发表于 2009-12-8 11:33:43 | 显示全部楼层
感恩!
GMT+8, 2025-12-23 08:28 , Processed in 0.020592 second(s), 5 queries , Gzip On, Redis On.
