查看: 3462|回复: 10
IEEE文章------《A Wide-Band High-Voltage Monolithic Amplifier》
发表于 2009-4-30 18:31:39 | 显示全部楼层 |阅读模式
作者------CARL R, BATTJES, MEMBER,IEEE
希望该文章对大家有帮助
Abstract
A monolithic amplifier capable of 80-V swing and 1.7-ns slew rate has been fabricated using standard integrated circuit techniques. The amplifier is
intended for capacitive loads such as in electrostatic deflection applications. The totem-pole technique is combined with active feedback to produce this
large voltage swing without excessive power consumption. A new output circuit linked with a floating current source is used to supply large accurate
positive and negative charging currents over a large dynamic range.The amplifier voltage range is extendable by increasing the degree of stacking in
the totem-pole arrangement.
[ 本帖最后由 嘉禾95 于 2009-4-30 18:33 编辑 ]
Wide-Band High-Voltage Monolithic Amplifier.pdf
1.03 MB, 下载次数: 62 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-4-30 18:35:06 | 显示全部楼层
自己顶一下!呵呵
发表于 2009-9-29 13:10:57 | 显示全部楼层
hv
gogogogogo
发表于 2010-3-11 16:08:15 | 显示全部楼层
谢谢楼主!
发表于 2010-11-9 21:33:55 | 显示全部楼层
Tanks for sharing~
发表于 2010-11-24 11:16:22 | 显示全部楼层
thanksaloy
发表于 2010-11-24 12:35:55 | 显示全部楼层
先顶一下
发表于 2016-5-23 17:23:33 | 显示全部楼层
THANK YOU
发表于 2017-11-25 23:21:49 | 显示全部楼层
发表于 2018-11-7 10:54:24 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-30 16:15 , Processed in 0.023743 second(s), 6 queries , Gzip On, Redis On.
