楼主: helte320
DFT 中set_autofix_configuration命令不对,希望高手指点原因 (复 代码)
发表于 2011-6-30 21:20:15 | 显示全部楼层
# Synopsys DC script
set design_top          [getenv DESIGN_TOP]
# DC setup
source library_setup.tcl
source common_setup.tcl
# Analyze & elaborate RTL source
read_file -format verilog ./dfttest.v
# Link design
link
# Check design
check_design
# Apply constraints
set auto_wire_load_selection true
#set_max_area 1500000
set_max_fanout 16 [get_designs *]
set_max_capacitance 2 [get_designs *]
set_load 0.1  [get_nets * ]
set_load 50   [all_outputs]
set bind_unused_hierarchical_pins true
   current_design dfttest
  create_clock -name "Fun_CLK" -period 20 -waveform { 0.000 10.000  }  { clk  }
   set_dont_touch_network clk
#******************************* insert scan **************************************
compile
set_scan_configuration -style multiplexed_flip_flop
set_scan_configuration -clock_mixing no_mix
set_scan_configuration -internal_clocks single
set_dft_signal -view spec -type scanenable -active 1 -port SCAN_ENA
set_dft_signal -view spec -type testmode -active 1 -port SCAN_TEST
set_dft_signal -view existing_dft -type TestMode    -port SCAN_TEST  -active_state 1
set_dft_signal -view existing_dft -type Reset       -port reset      -active_state 0
set_dft_signal -view existing_dft -type ScanClock   -port SCAN_CLK   -timing {45 55}
set_dft_signal -view existing_dft -type ScanEnable  -port SCAN_ENA   -active_state 1
set_dft_signal -view spec         -type ScanDataIn  -port PIN_SI
set_dft_signal -view spec         -type ScanDataOut -port PIN_SO
set_scan_configuration -chain_count 1
set_scan_path -view spec c0 -scan_data_in PIN_SI -scan_data_out PIN_SO
#set_autofix_configuration -type clock -control_signal SCAN_TEST -test_data PIN_SI
#set_autofix_configuration -type reset -control_signal SCAN_TEST -test_data PIN_SO
#compile -scan
create_test_protocol
# -capture_procedure multi_clock
preview_dft
insert_dft
report_constraint -all_violators
report_scan_path
dft_drc -verbose -coverage_estimate
write_test_protocol -output dfttest.spf
#*********************** * end insert scan  *****************************
# Uniquify
uniquify
# Pass0 compile
compile_ultra
# Report timing & area
report_cons -all_vio
report_timing -max 100
report_area
report_area -hierarchy
# Write out netlist
change_names -rules verilog -hier
write -f verilog -hier -o $design_top.vn
write -f ddc -hier -o $design_top.ddc
发表于 2011-6-30 21:29:19 | 显示全部楼层
上面跑过可以用。
发表于 2014-3-11 11:04:13 | 显示全部楼层
回复 9# xiaocanmeng
请问一下,那这里面的test_data是自己要重新定义的的端口信号吗?
发表于 2014-4-1 17:21:09 | 显示全部楼层
回复 6# cangyufan
    你好,set_autofix_configuration -testdata 后面是不是需要一个clock信号,而且该clock信号必需首先使用set_dft_signal -type scanclock 定义?本人不确定,请指教。
发表于 2016-1-24 17:40:43 | 显示全部楼层
thank you for good info
回复 支持 0 反对 1
发表于 2018-12-31 14:29:48 | 显示全部楼层
看看脚本
发表于 2020-1-15 11:21:29 | 显示全部楼层
mark......
发表于 2020-8-28 10:29:03 | 显示全部楼层
这里的控制信号应该是TEST_MODE的端口名,而不是类型名
发表于 2020-11-3 17:50:32 | 显示全部楼层
不需要autofix了吗
GMT+8, 2025-9-12 19:55 , Processed in 1.098908 second(s), 4 queries , Gzip On, Redis On.
