查看: 3451|回复: 4
IEEE_JNL_2008_A Novel Topology for Photovoltaic DC-DC
发表于 2009-4-7 16:00:02 | 显示全部楼层 |阅读模式
本文為IEEE JNL文件
標題:
A Novel Topology for Photovoltaic DC-DC Full-Bridge Converter With Flat Efficiency Under Wide PV Module Voltage and Load Range
Jong-Pil Lee, Byung-Duk Min, Tae-Jin Kim, Dong-Wook Yoo, and Ji-Yoon Yoo, Member, IEEE
Abstract
In this paper, a novel topology for a photovoltaic (PV)dc/dc converter that can dramatically reduce the power rating andincrease the efficiency of a PV system by analyzing PV modulecharacteristics is proposed. Based on the analysis, in the proposedtopology, only 30.7% power of the total PV system is neededfor a dc/dc converter. Furthermore, the dc/dc converter efficiencycurve is flat under wide PV module voltage and all load ranges.In particular, the converter efficiency at the lower duty rangeis dramatically improved. The total PV system is implementedfor a 250-kW PV power conditioning system (PCS). This systemhas only three dc/dc converters with a 25-kW power rating. It isonly one-third of the total PV PCS power. The 25-kW prototypePV dc/dc converter is introduced to experimentally verify theproposed topology. In addition, an experimental result shows thatthe proposed topology exhibits a good performance.Index Terms—DC/DC full-bridge converter, photovoltaic (PV)power conditioning system (PCS), voltage balance control, zerovoltageswitching (ZVS).
abbr_3d10fadd9e33cf6b4de8d2f5d6eed4cf.pdf
1.32 MB, 下载次数: 45 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-11-6 16:33:37 | 显示全部楼层
谢谢你的
发表于 2013-11-16 09:51:00 | 显示全部楼层
Good sharing!!!
发表于 2016-6-19 09:57:16 | 显示全部楼层
THANK YOU
发表于 2022-11-1 16:25:11 | 显示全部楼层
:lol:lol
GMT+8, 2025-12-28 22:26 , Processed in 0.028950 second(s), 7 queries , Gzip On, Redis On.
