查看: 5544|回复: 14
How to plot the DC gain vs Vout,diff?
发表于 2009-4-2 11:30:03 | 显示全部楼层 |阅读模式
When we do differential op design,need to check the op dc gain change with the differential output swing to sure the dc gain is ok for different output swing.we can use input  do  .DC sweep to get the output swing range ,but how to plot the DC gain vs Vout,diff use hspice or spectre?just like the paper follower. Thanks! 240_Liu_ProjReport.pdf (397.14 KB , 下载次数: 41 )
 楼主| 发表于 2009-4-2 12:39:55 | 显示全部楼层
nobody to reply?
发表于 2009-4-2 13:23:59 | 显示全部楼层
What kind of viewer like awave or cosmoscope are you using ? Maybe you can try to derivate the output voltage.
发表于 2010-4-20 12:16:40 | 显示全部楼层
这个我也不懂
发表于 2010-4-20 12:47:17 | 显示全部楼层
下来看看
发表于 2010-4-20 16:09:55 | 显示全部楼层
可以参考李福乐那片OTA文章里的仿真方法
发表于 2010-4-20 18:12:34 | 显示全部楼层
wavescan 里可以
发表于 2010-4-20 18:21:39 | 显示全部楼层
just like this?
发表于 2010-4-20 22:37:20 | 显示全部楼层
thank you
发表于 2010-4-22 09:03:08 | 显示全部楼层
下来看看
GMT+8, 2025-12-7 07:21 , Processed in 0.026275 second(s), 8 queries , Gzip On, Redis On.
