查看: 3029|回复: 3
有人知道在时序分析器中看到的Tsrck什么意思吗,为什么在data sheet中找不到
发表于 2009-3-30 14:24:20 | 显示全部楼层 |阅读模式
如题,有人能指教下在哪里找吗,DATASHEET中找不到
发表于 2009-3-30 19:41:47 | 显示全部楼层
来自于Viretex-4 FPGA User Guide的一句话
Tsrck/Tcksr:Time before Clock(CLK) that the SR (Set/Reset) and the BY(Rev) inputs of the slice must be stable at the SR/Rev-inputs of the slice sequential elements(configured as a flip-flop).Synchronous set/reset only.
附图说明为:
At time Tsrck before clock event(3), the SR signal(configured as synchronous reset in this case) becomes valid-high, resetting the slice register.This is reflected on the XQ or YQ pin at time Tcko after clock event(3).
Tsrck
Tsrck
发表于 2009-3-30 19:50:53 | 显示全部楼层
希望对你有用
 楼主| 发表于 2009-3-30 20:37:47 | 显示全部楼层
谢谢,真是我所想要的,我的PROJECT是建立在V2P上的,所以查不到
GMT+8, 2025-12-26 09:00 , Processed in 0.017302 second(s), 5 queries , Gzip On, Redis On.
