查看: 3160|回复: 1
calibre antenna 的问题(有请各路高手在此贴一聚)
发表于 2009-3-30 14:12:17 | 显示全部楼层 |阅读模式
我在encounter 里routing之后verify antenna没有查出violation。
但是到calibre check antenna时报了近300个错误,错误信息如下:
Rule File Pathname: /home/cwg/cds/_SmicAT4TSP8R_cal018_mixlog_p1mt6.ant_
Max. (M3 perim*thickness / gate area) is 400 (without effective diode)
Max. (M3 perim*thickness / gate area) is Ratio Equation (with effective diode)
Max. (M4 perim*thickness / gate area) is 400 (without effective diode)
Max. (M4 perim*thickness / gate area) is Ratio Equation (with effective diode)
Max. (M5 perim*thickness / gate area) is 400 (without effective diode)
Max. (M5 perim*thickness / gate area) is Ratio Equation (with effective diode)
(V5 area / gate area) > 20 (without effective diode)
(V5 area / gate area) > Ratio Equation (with effective diode)
我比较了一下encounter里用的antenna的lef文件和calibre里的ant文件对于M3.M4.M5和V5的定义如下:
antenna的lef文件:
LAYER METAL3
    Thickness 0.53 ;
    AntennaSideAreaRatio 396 ;
    AntennaDiffSideAreaRatio PWL ( ( 0 396 ) ( 0.201 396 ) ( 0.202 1980 ) ( 0.404 3960 ) ) ;
END METAL3
LAYER METAL4
    Thickness 0.53 ;
END METAL4
LAYER METAL5
    Thickness 0.53 ;
END METAL5
LAYER VIA56
    AntennaAreaRatio 20 ;
    AntennaDiffAreaRatio PWL ( ( 0 20 ) ( 0.201 20 ) ( 0.202 74.00 ) ( 0.404 148.00 ) ) ;
END VIA56
calibre里的ant文件:
//    M3 Layer
CONNECT M3 M2 BY V2
CONNECT V3 M3
M3_DIO = NET AREA SD  >=0.203 // minimum effective diode 0.203um2
ANT.GT.2_3.M3 {
@ Max. (M3 perim*thickness / gate area) is 400 (without effective diode)
@ Max. (M3 perim*thickness / gate area) is Ratio Equation (with effective diode)
  NET AREA RATIO GT M1 M2 M3 V3 M3_DIO GATE > 400
      [ PERIMETER(M3)*0.53/AREA(GATE) - (AREA(M3_DIO)*400 + !!AREA(M3_DIO)*1800) ]
  RDB ANT_GT23_M3.rep GT M1 M2 M3 M3_DIO GATE
//    M4 Layer
CONNECT M4 M3 BY V3
CONNECT V4 M4
M4_DIO = NET AREA SD  >=0.203 // minimum effective diode 0.203um2
ANT.GT.2_3.M4 {
@ Max. (M4 perim*thickness / gate area) is 400 (without effective diode)
@ Max. (M4 perim*thickness / gate area) is Ratio Equation (with effective diode)
  NET AREA RATIO GT M1 M2 M3 M4 V4 M4_DIO GATE > 400
      [ PERIMETER(M4)*0.53/AREA(GATE) - (AREA(M4_DIO)*400 + !!AREA(M4_DIO)*1800) ]
  RDB ANT_GT23_M4.rep GT M1 M2 M3 M4 M4_DIO GATE
//    M5 Layer
CONNECT M5 M4 BY V4
CONNECT V5 M5
M5_DIO = NET AREA SD  >=0.203 // minimum effective diode 0.203um2
ANT.GT.2_3.M5 {
@ Max. (M5 perim*thickness / gate area) is 400 (without effective diode)
@ Max. (M5 perim*thickness / gate area) is Ratio Equation (with effective diode)
  NET AREA RATIO GT M1 M2 M3 M4 M5 V5 M5_DIO GATE > 400
      [ PERIMETER(M5)*0.53/AREA(GATE) - (AREA(M5_DIO)*400 + !!AREA(M5_DIO)*1800) ]
  RDB ANT_GT23_M5.rep GT M1 M2 M3 M4 M5 M5_DIO GATE
//   V5 Layer
ANT.GT.5_6.V5 {
@ (V5 area / gate area) > 20 (without effective diode)
@ (V5 area / gate area) > Ratio Equation (with effective diode)
  NET AREA RATIO GT M1 M2 M3 M4 M5 V5 M5_DIO GATE > 20
      [ AREA(V5)/AREA(GATE) - (AREA(M5_DIO)*83.33 + !!AREA(M5_DIO)*55) ]
  RDB ANT_GT56_V5.rep GT M1 M2 M3 M4 M5 V5 M5_DIO GATE
现在我的问题就是根据calibre里的ant文件来改antenna的lef文件,具体应该怎么改呢?
发表于 2009-4-13 01:19:50 | 显示全部楼层
謝謝樓主發帖,頂上去。
謝謝樓主共享,頂上去。
謝謝樓主共享,頂上去。
GMT+8, 2025-12-24 23:25 , Processed in 2.275404 second(s), 6 queries , Gzip On, Redis On.
