查看: 3936|回复: 16
A G m -C continuous-time analog filter for IEEE 802.11 abgn wireless
发表于 2009-3-27 10:08:04 | 显示全部楼层 |阅读模式
A G m -C continuous-time analog filter for IEEE 802.11 abgn wireless LANs.pdf
447.45 KB, 下载次数: 135 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-3-27 18:03:21 | 显示全部楼层
luguo
发表于 2010-3-29 20:13:32 | 显示全部楼层
thanks a lot!
发表于 2010-8-11 19:02:42 | 显示全部楼层
thanks a lot!
发表于 2010-8-17 13:51:52 | 显示全部楼层
下来看看 谢谢
发表于 2010-12-22 12:24:11 | 显示全部楼层
回复 1# schwang
    good!
发表于 2010-12-29 10:38:23 | 显示全部楼层
我理解错了,索性把abstract贴上来,免得其它人下载了才明白,不好意思。
A CMOS transconductor for multi-mode wireless channel selection filter is presented. The linear transconductor is designed based on the flipped-voltage follower (FVF) circuit and an active resistor to achieve the transconductance tuning. The transconductance tuning can be obtained by changing the bias current of the active resistor. A third-order Butterworth low-pass filter implemented with the transconductors was designed by TSMC 0.18-lm CMOS process. The results show that the filter can operate with the cutoff frequency of 10–20 MHz. The tuning range would be suitable for the specifications of
IEEE 802.11 a/b/g/n Wireless LANs under the consideration of saving chip areas. In the design, the maximum power consumption is 13 mW with the cutoff frequency of 20 MHz under a 1.8 V supply voltage.
发表于 2011-1-5 13:30:36 | 显示全部楼层
VERY GOOD
发表于 2011-1-5 13:35:38 | 显示全部楼层
LOOKS GREAT
发表于 2011-2-19 06:07:53 | 显示全部楼层
下来看下先。。。
GMT+8, 2025-12-25 19:32 , Processed in 0.023180 second(s), 8 queries , Gzip On, Redis On.
