查看: 18459|回复: 73
合理利用latch解决时序问题
发表于 2009-3-16 14:15:54 | 显示全部楼层 |阅读模式
事实证明,这是很好的一种方法,只是在使用的时候要注意其约束方式...
Timing+optimization+by+replacing+flip-fl[1]....pdf
409.28 KB, 下载次数: 647 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-3-16 14:17:24 | 显示全部楼层
自己的帖子,自己顶
发表于 2009-3-16 16:12:20 | 显示全部楼层
Timing Optimization by Replacing Flip-Flops to Latches
简介atch circuits have advantage for timing and are widely used fur high-speed custom circuits. However, ASIC design flows are h don the circuits with flip-flops. Then, ASIC designers don't use latches. This paper describes a new timing optimization algorithm for ASIC by replacing flip-flops to latches without changing the functionality of the circuits. After latch replacement, mstricted retiming called fixed-phase retiming is carried out for timing optimization by minimizing the impact of clock skew and jitter. The experimental results show that 17% delay improvement of the benchmark circuits is achieved by proposed algorithms.
发表于 2009-3-16 16:58:56 | 显示全部楼层
3ks3ks
发表于 2009-7-30 07:50:48 | 显示全部楼层
good, thanks.
发表于 2009-7-30 10:25:47 | 显示全部楼层
这个题目很有意思,多谢。
发表于 2009-7-30 11:08:12 | 显示全部楼层
辛苦楼主,谢谢分享
发表于 2009-10-17 16:37:01 | 显示全部楼层
thank you!
头像被屏蔽
发表于 2009-10-17 18:11:13 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-10-18 09:10:31 | 显示全部楼层
老外的论文 可以看看
GMT+8, 2025-12-22 20:27 , Processed in 0.027605 second(s), 8 queries , Gzip On, Redis On.
