查看: 2620|回复: 5
hspice的Avanwaves问题
发表于 2009-3-10 15:09:50 | 显示全部楼层 |阅读模式
每次仿真后,都要从新打开波形文件,有没有什么方法可以直接刷新看最新仿真结果?迹象cscope一样。
请对Hspice熟悉的高人解答下谢谢
发表于 2009-3-11 03:12:19 | 显示全部楼层
Actually you can use update button. But sometimes does not work.
As I told you, Synopsys guys never make any improvements for Avanwaves and HSPICE core for a very long time. They actually never support avanwaves. Change to Cscope pls.
发表于 2009-3-12 10:08:44 | 显示全部楼层
buy new graphic card
 楼主| 发表于 2009-3-12 21:40:42 | 显示全部楼层
谢谢楼上的。已经解决
发表于 2009-3-28 07:38:13 | 显示全部楼层
EZWAVE是ctr+R,不知道ANAWAVE是啥,可以试试
发表于 2009-8-5 21:48:46 | 显示全部楼层
没记错的话win版本好像是ctrl+U
GMT+8, 2025-12-25 13:09 , Processed in 0.021166 second(s), 6 queries , Gzip On, Redis On.
