发表于 2009-3-11 10:12:37
显示全部楼层
According to your PN plots, your VCO running at 9Ghz, several peaks(spurs) can be seen within its 100Khz neigbhour. Many cases might be fine since they are pretty small already. However, you have to figure out where they come from. Ideal simulation for the PN of VCO should be much smoothy than that. |
