查看: 2488|回复: 1
如何通过综合工具综合后给出的一个报告修改优化自己的设计?
发表于 2009-3-6 11:04:15 | 显示全部楼层 |阅读模式
以下面我写的为例子
还请高手指点拉
原代码:
assign Transmite_Task_Sign  =~(|NUM_SIGN_r);
always @(posedge i_Clock or negedge i_Reset_n)
  if(~i_Reset_n)
   NUM_SIGN_r<=0;
  else begin
    case ({UART_WR_SWITCH,Transmite_OK_reg})
     2'b10:NUM_SIGN_r<=NUM_SIGN;
     2'b01:if(NUM_SIGN_r!==0)NUM_SIGN_r<=NUM_SIGN_r-1;
     default:NUM_SIGN_r<=NUM_SIGN_r;
    endcase
   end
报告:
Worst slack in design: -0.836
                     Requested     Estimated     Requested     Estimated                Clock        Clock
Starting Clock       Frequency     Frequency     Period        Period        Slack      Type         Group
I2C_TEST|i_Clock     263.4 MHz     215.9 MHz     3.796         4.632         -0.836     inferred     Autoconstr_clkgroup_0
Starting Points with Worst Slack
        Starting        Arrival
Instance                                                              Reference            Type                   Pin        Net                Time        Slack
        Clock
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[0]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[0]      0.255       -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[1]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[1]      0.255       -0.817
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[4]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[4]      0.255       -0.688
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[5]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[5]      0.255       -0.669
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[16]     I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[16]     0.255       -0.669
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[8]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[8]      0.255       -0.561
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[9]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[9]      0.255       -0.542
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[17]     I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[17]     0.255       -0.542
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[2]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[2]      0.255       -0.521
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[3]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[3]      0.255       -0.394
Ending Points with Worst Slack
        Starting        Required
        Clock
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[0]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[1]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[2]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[3]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[4]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[5]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[6]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[7]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[8]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[9]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     NUM_SIGN_rlde_0     3.133        -0.836
修改后的代码:
assign TX_Baudrate_Clock_Stop=Transmite_Task_Finish & StopCHECK_Ack;
  reg d1;
reg d2;
reg d3,d4,d5,d6,d7,d8,d9,d10;
reg Transmite_Task_Sign;
if(~i_Reset_n)begin
d1<=0;
d2<=0;
d3<=0;
d4<=0;
d5<=0;
d6<=0;
d7<=0;
d8<=0;
d9<=0;
d10<=0;
Transmite_Task_Sign<=0;
end
else begin
d1<=|NUM_SIGN_r[1:0];
d2<=|NUM_SIGN_r[5:3];
d3<=|NUM_SIGN_r[8:6];
d4<=|NUM_SIGN_r[11:9];
d5<=|NUM_SIGN_r[14:12];
d6<=|NUM_SIGN_r[17:15];
d7<=d1 | d2;
d8<=d3 | d4;
d9<=d5 | d6;
d10<=d7 | d8 | d9;
Transmite_Task_Sign<=~d10;
end
报告:
Worst slack in design: -0.601
I2C_TEST|i_Clock     293.8 MHz     249.7 MHz     3.404         4.005         -0.601     inferred     Autoconstr_clkgroup_0
        Starting        Arrival
        Clock
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[8]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[8]            0.255       -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[11]     I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[11]           0.255       -0.582
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[1]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[1]            0.255       -0.500
UART_Controller.Baudrate_Clock_Generator.RX_Clock_Div_Cnt[14]         I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     RX_Clock_Div_Cnt[14]     0.255       -0.462
UART_Controller.Baudrate_Clock_Generator.TX_Clock_Div_Cnt[14]         I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     TX_Clock_Div_Cnt[14]     0.255       -0.462
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[6]      I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     NUM_SIGN_r[6]            0.255       -0.453
UART_Controller.Baudrate_Clock_Generator.RX_Clock_Div_Cnt[15]         I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     RX_Clock_Div_Cnt[15]     0.255       -0.443
UART_Controller.Baudrate_Clock_Generator.RX_Clock_Div_Cnt_i[6]        I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     RX_Clock_Div_Cnt_i_6     0.255       -0.443
UART_Controller.Baudrate_Clock_Generator.TX_Clock_Div_Cnt[15]         I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     TX_Clock_Div_Cnt[15]     0.255       -0.443
UART_Controller.Baudrate_Clock_Generator.TX_Clock_Div_Cnt_i[6]        I2C_TEST|i_Clock     cycloneii_lcell_ff     regout     TX_Clock_Div_Cnt_i_6     0.255       -0.443
        Starting                                                         Required
        Clock
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[0]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[1]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[2]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[3]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[4]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[5]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[6]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[7]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[8]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
UART_Controller.UART_Transmiter.Transmite_Data_CTR.NUM_SIGN_r[9]     I2C_TEST|i_Clock     cycloneii_lcell_ff     ena     N_1768_i     2.741        -0.601
发表于 2009-3-6 16:57:37 | 显示全部楼层
看不懂哎,望高手指点下
GMT+8, 2025-12-26 09:06 , Processed in 0.023065 second(s), 6 queries , Gzip On, Redis On.
