发表于 2012-10-9 14:12:40
显示全部楼层
楼主,你丫太TM不厚道,随便弄个附件来骗信元啊?
你附件中哪一句说vdsat要取小一点了?
signal current. As described in section 3.1.4, this ensures weakly nonlinear
behavior of the circuit even at high frequencies.
The small-signal equivalent of the opamp is shown in Figure 3-11. The
folded cascode is replaced with a linear resistor equal to the resistance seen
into the drains of M9 and M11. This simplification was necessary to avoid
high complexity in the expressions for The main
contributions to distortion are expected to come from the transistors that are
exposed for the highest signal swing. Since the folded cascode does not have
large voltage swing at any of its nodes, the estimated distortion will still be
relatively accurate. The effect of the approximation will be visualized in
Chapter 5 where the simulation results obtained with Maple and Eldo will be
compared.
The transfer functions given in (3-7) to (3-9) will be found using the
small-signal model in Figure 3-11. The procedure used is explained in
Appendix C, where it is carried out to obtain the transfer functions of
order. Because of the large complexity the higher order transfer functions are
carried out in Maple and not shown in Appendix C. The derivation of the
nonlinear transfer functions of the opamp is similar to the derivation for the
LP-filter carried out in section 2.3.1. |
