查看: 3760|回复: 3
ntb_load出错
发表于 2009-2-23 21:24:14 | 显示全部楼层 |阅读模式
dynamic loading failed
simv文件是别人编译好的 我们使用的vcs版本号相同 机器相同
但就是在用他的simv文件加载我的libtb.so时不成功
发表于 2009-2-23 22:56:12 | 显示全部楼层
It could be a problem of version of dynamical linker.
ask you system administrator to make sure that the version of the default  system dynamic linker and the version of vcs dynamic linker are same.
 楼主| 发表于 2009-2-24 21:37:42 | 显示全部楼层
谢谢
dynamical linker版本和vcs版本是分开的?
发表于 2009-2-24 21:41:47 | 显示全部楼层
Yes.
VCS use own gcc linker version, which could be different from your system-wide installed gcc dynamic linker version.
GMT+8, 2025-12-30 05:44 , Processed in 0.030117 second(s), 6 queries , Gzip On, Redis On.
