查看: 26725|回复: 103
新GPS and Galileo.Dual RF Front-end receiver and Design, Fabrication, And Test
发表于 2009-2-22 13:14:17 | 显示全部楼层 |阅读模式
GPS and Galileo_ Dual RF Front-end receiver and Design, Fabrication, And Test
Publisher:   McGraw-Hill Professional
Number Of Pages:   208
Publication Date:   2008-11-17
ISBN-10 / ASIN:   0071598693
ISBN-13 / EAN:   9780071598699
Design State-of-the-Art GPS/Galileo Dual RF Receivers
This authoritative guide walks you through the process of designing, fabricating, and testing a highly integrated, low-noise, low-power, and low-cost RF front-end for GPS and Galileo, the leading satellite-based global navigation systems. Everything from standards analysis to characterization of the design is covered in the book.
GPS Andamp; Galileo focuses on developing seamlessly interoperable receivers that can access the wide variety of new services offered by these systems, such as increased service availability, centimeter-sensitive accuracy, emergency management, and data confidentiality. By the end of the book, you will have a prototype that achieves peak performance in terms of gain, NF, and current consumption, making it suitable for any high-accuracy, portable application.
Discover how to:
Determine the specifications of an interoperable dual GPS/Galileo RF front-end
Design all RFIC blocks, including the receiver chain, PLL, control logic, and PADs
Select the required external components
Implement optimal floor planning
Perform validation testing of the integrated RF front-end
Understand real-world fields of application
Gauge the performance of the front-end within a receiver linked to a full-solution platform
好久没有来论坛了,这书送给大家。
GPS and Galileo_ Dual RF Front-end receiver and Design, Fabrication, And Test.pdf
3.17 MB, 下载次数: 872 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-2-22 19:32:44 | 显示全部楼层
good
thanks
发表于 2009-2-23 00:57:12 | 显示全部楼层
下一章,顶一次,永远不要沉下去。op
发表于 2009-2-23 21:50:02 | 显示全部楼层
thank you
发表于 2009-2-23 21:51:13 | 显示全部楼层
thank you
发表于 2009-2-23 22:07:20 | 显示全部楼层
看看和我们做得有啥不一样
发表于 2009-2-23 22:19:53 | 显示全部楼层
eetop
发表于 2009-2-24 09:30:46 | 显示全部楼层
thanks!
发表于 2009-2-24 09:35:59 | 显示全部楼层
so good !
发表于 2009-2-24 12:34:56 | 显示全部楼层
good!
GMT+8, 2025-12-28 15:05 , Processed in 0.023507 second(s), 6 queries , Gzip On, Redis On.
