查看: 3563|回复: 6
对Nios有了解的朋友进来帮个忙
发表于 2004-2-19 21:31:56 | 显示全部楼层 |阅读模式
我现在作Nios开发,刚刚着手,由于资料甚多,自感没有主次,望指点该如何做才能有层次的逐步提高!
不胜感激!
发表于 2004-2-20 11:57:46 | 显示全部楼层
对Nios有了解的朋友进来帮个忙
Start from the hardware design first. try to understand all the addressing, interfacing and etc. Then read the software design manual properly. study the details of the nios instruction and try to related to the hardware architecture. Try to design some basic system such as web server, and echo server. Try to go into the details of file system management, read and write mechanism through the storage. Finally, if your financial allowed, further your research into the embedded linux such as microtronix uclinux. Good luck for you.
发表于 2004-2-20 14:54:19 | 显示全部楼层
对Nios有了解的朋友进来帮个忙
我研究nios大半年,基于cyclone的
正在研究如何在平台上跑ucos2
也许我们可以聊聊
 楼主| 发表于 2004-2-20 20:43:25 | 显示全部楼层
对Nios有了解的朋友进来帮个忙
多谢周兄指点!
发表于 2004-3-11 09:40:20 | 显示全部楼层
对Nios有了解的朋友进来帮个忙
我已经跑起来了ucos2
发表于 2004-3-11 15:57:50 | 显示全部楼层
对Nios有了解的朋友进来帮个忙
jzwanghua ,请指点!
发表于 2004-4-18 18:19:15 | 显示全部楼层
对Nios有了解的朋友进来帮个忙
jzwanghua,你好
我是刚接触Nios的新手,正在Cyclone的评估板上试,打算将uCOSII移植到Nios,用StratixII,能否将你已实现移植的uCOSII代码给我一份供参考,谢谢!
我的email:dialsun@sohu.com
GMT+8, 2025-12-20 04:18 , Processed in 0.021300 second(s), 9 queries , Gzip On, Redis On.
