查看: 3877|回复: 11
Embedded image feature extraction system on a single FPGA chip
发表于 2009-2-17 15:35:01 | 显示全部楼层 |阅读模式
論文題目:Embedded image feature extraction system on a single FPGA chip
論文編號:MR01872
論文作者:Wang, Wenxin
學位名稱:M.Sc.
畢業學校:University of Guelph (Canada) (0081)
畢業年份:2005
論文頁數:121
原始資料:DAI Vol 43-06, page: 2368
主題分類:Engineering, Electronics and Electrical (0544);Computer Science (0984)
論文摘要:The motivation behind this research is to develop a prototype system of real-time corner detection for portable multimedia devices. A number of corner detection algorithms were analyzed. The advantages and disadvantages of each algorithm were identified. The Plessy algorithm was found to have good stability, accuracy, significantly better performance in natural images and was the most appropriate algorithm for hardware implementation. To overcome the weakness of the board-based designs, the Plessy algorithm was implemented on a single FPGA chip by using a hardware/software co-design of the embedded system. This approach aims to take advantage of the high performance of FPGAs and the flexibility of the processor(s). The results show that this prototype system can achieve more than 3 times throughput than previous board-based designs. The input of this system is a gray level image with a high bandwidth and the output is a set of image corner locations with a low bandwidth. The hardware and software can be processed in parallel and also can be modified or replaced rapidly and conveniently.
Embedded image feature extraction system on a single FPGA.part1.rar
3.81 MB, 下载次数: 52 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Embedded image feature extraction system on a single FPGA.part2.rar
1.15 MB, 下载次数: 49 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-2-18 16:34:39 | 显示全部楼层
THANK
发表于 2010-2-26 15:45:21 | 显示全部楼层
study
发表于 2010-2-26 15:49:42 | 显示全部楼层
again
发表于 2010-2-28 21:31:53 | 显示全部楼层
thanks
发表于 2010-10-9 02:15:35 | 显示全部楼层
Thanks
发表于 2010-10-11 06:54:14 | 显示全部楼层
thanks for sharing
发表于 2010-10-12 13:57:02 | 显示全部楼层
thanks a lot!
发表于 2010-10-12 14:20:54 | 显示全部楼层
rftrectweq
发表于 2010-10-12 16:04:35 | 显示全部楼层
路过看看
GMT+8, 2025-11-8 04:46 , Processed in 0.026478 second(s), 8 queries , Gzip On, Redis On.
