查看: 8521|回复: 4
SOPC 在generation时遇到的问题
发表于 2009-2-17 00:59:34 | 显示全部楼层 |阅读模式
系统设计好之后点击“generator”,提示:
Warning: reconfig_request_pio: PIO inputs are not hardwired in test bench. Undefined values will be read from PIO inputs during simulation.
Info: ext_flash: Flash memory capacity: 16.0 MBytes (16777216 bytes).
Info: Wrote C:/EDA/Altera/81/nios2eds/examples/verilog/niosII_cycloneII_2c35/standard/NiosII_cycloneII_2c35_standard_sopc.sopcinfo
Info: NiosII_cycloneII_2c35_standard_sopc: Generating QIP file.
Info: Info: *******************************************************************
Info: Info: Running Quartus II Shell
Info:     Info: Version 8.1 Build 163 10/28/2008 SJ Full Version
Info:     Info: Copyright (C) 1991-2008 Altera Corporation. All rights reserved.
Info:     Info: Your use of Altera Corporation's design tools, logic functions
Info:     Info: and other software and tools, and its AMPP partner logic
Info:     Info: functions, and any output files from any of the foregoing
Info:     Info: (including device programming or simulation files), and any
Info:     Info: associated documentation or information are expressly subject
Info:     Info: to the terms and conditions of the Altera Program License
Info:     Info: Subscription Agreement, Altera MegaCore Function License
Info:     Info: Agreement, or other applicable license agreement, including,
Info:     Info: without limitation, that your use is for the sole purpose of
Info:     Info: programming logic devices manufactured by Altera and sold by
Info:     Info: Altera or its authorized distributors.  Please refer to the
Info:     Info: applicable agreement for further details.
Info:     Info: Processing started: Tue Feb 17 00:48:59 2009
Info: Info: Command: quartus_sh -t sopc_add_qip_file.tcl
Info: Info: Evaluation of Tcl script sopc_add_qip_file.tcl was successful
Info: Info: Quartus II Shell was successful. 0 errors, 0 warnings
Info:     Info: Peak virtual memory: 81 megabytes
Info:     Info: Processing ended: Tue Feb 17 00:48:59 2009
Info:     Info: Elapsed time: 00:00:00
Info:     Info: Total CPU time (on all processors): 00:00:00
Info: Starting PTF file elaboration.
之后一直停在这,CPU占用50%(perl.exe程序占用),
在任务管理器中结束perl.exe程序后提示“failed to refresh ptf file”
然后开始“generation”,同样,停在这儿了,还是perl.exe占用50%的cpu,
在任务管理器中结束perl.exe后,提示“system generation failed”。
我的系统是Windows Server 2008,quartus 8.1版本,不知是不是版本不兼容?
 楼主| 发表于 2009-2-17 10:28:43 | 显示全部楼层
楼上的,不能这样灌水吧!
发表于 2009-2-17 12:31:48 | 显示全部楼层
灌水的不地道呀
 楼主| 发表于 2009-2-18 23:19:13 | 显示全部楼层
还是由于不兼容引起的,参考国外的帖子,解决方法如下(原帖针对7.2版本,不过对8.1也适用):
HOW TO MAKE NIOSII EDS VISTA COMPATIBLE
1) Download the Cygwin-installer from http://www.cygwin.com/setup.exe
2) Run install.exe while online (i did not check if it makes provision for a proxy server )
3) When asked the install directory ( Default c:\cygwin ) browse to and select c:\altera\72\quartus\bin\cygwin as the install dir
4) Let install update cygwin to the newest version
Just tested it on Vista Ultimate with full current updates Generate in SOPC builder now works fine , compile is ok and compiling Hello world works correct
It's tricky when you update cygwin files..that is , you cannot update all new files,but only default ones.
You might rename .../cygwin/etc to .../cygwin/etcold and try again.By the way, when running cygwin setup.exe,choose Dos/text as Default text file type.
7.2 Sp1 updated cygwin files,but still not working by default. Anyway , quartus and nios now support Vista better than before. Hope working on server2008!
Good Luck!
仅供参考!
发表于 2009-2-19 02:11:47 | 显示全部楼层
顶楼主一个   呵呵
爱拼才会赢!!金山毒霸新蛋凡客欢乐斗地主杀毒软件
GMT+8, 2025-12-26 20:39 , Processed in 0.045693 second(s), 7 queries , Gzip On, Redis On.
