查看: 11124|回复: 35
一篇价值极高的JSSC论文,详细论述了采用digital polar结构的RF PA,作者有大牛Wooley
发表于 2009-2-13 22:31:02 | 显示全部楼层 |阅读模式
作者包括好几个IEEE Fellow,包括大牛Wooley,本文原载于JSSC 2008 -Issue 10
Abstract—This paper presents a CMOS RF power amplifier that
employs a digital polar architecture to improve the overall power
efficiency when amplifying signals with high linearity requirements.
The power amplifier comprises 64 parallel RF amplifiers
that are driven by a constant envelope RF phase-modulated signal.
The unit amplifiers are digitally activated by a 6-bit envelope
code to construct a non-constant envelope RF output, thereby
performing a digital-to-RF conversion. In order to suppress the
spectral images resulting from the discrete-time to continuous-time
conversion of the envelope, the use of oversampling and four-fold
linear interpolation is explored. An experimental prototype of
the polar amplifier has been integrated in a 0.18- m CMOS
technology, occupies a total die area of 1.8 mm2, operates at a
1.6-GHz carrier frequency with a channel bandwidth of 20 MHz.
For an OFDM signal, it achieves a power-added efficiency of 6.7%
with an EVM of 26.8 dB while delivering 13.6 dBm of linear
output power and drawing 145 mA from a 1.7-V supply.
Index Terms—CMOS RF, IEEE 802.11g, L-fold linear interpolation,
polar transmitter, power amplifier.
A Digitally Modulated Polar CMOS Power Amplifier With a 20-MHz Channel Bandwidth.pdf (1.41 MB , 下载次数: 418 )
 楼主| 发表于 2009-2-15 20:48:59 | 显示全部楼层
发表于 2009-2-15 20:57:09 | 显示全部楼层
eetop
发表于 2009-2-16 13:39:40 | 显示全部楼层
eetop
eetop
eetop
发表于 2009-10-19 17:47:31 | 显示全部楼层
dd
发表于 2009-10-20 02:04:02 | 显示全部楼层
thanks for sharing!!!!
发表于 2009-10-20 03:19:10 | 显示全部楼层
好书好书
发表于 2009-10-20 05:00:39 | 显示全部楼层
好好,看看
发表于 2009-10-20 15:03:09 | 显示全部楼层
好书好书
发表于 2010-3-6 18:54:12 | 显示全部楼层
感谢分享
GMT+8, 2025-12-24 23:34 , Processed in 0.032405 second(s), 8 queries , Gzip On, Redis On.
