查看: 4255|回复: 8
[原创] 论题大家谈:在项目开发中是选FPGA还是DSP
发表于 2006-2-28 22:59:19 | 显示全部楼层 |阅读模式
FPGA or DSP
The DSP is a specialised microprocessor - typically programmed in C, perhaps with assembly code for performance. It is well suited to extremely complex maths-intensive tasks, with conditional processing. It is limited in performance by the clock rate, and the number of useful operations it can do per clock. As an example, a TMS320C6201 has two multipliers and a 200MHz clock – so can achieve 400M multiplies per second.
In contrast, an FPGA is an uncommitted "sea of gates". The device is programmed by connecting the gates together to form multipliers, registers, adders and so forth. Using the Xilinx Core Generator his can be done at a block-diagram level. Many blocks can be very high level – ranging from a single gate to an FIR or FFT. Their performance is limited by the number of gates they have and the clock rate. Recent FPGAs have included Multipliers especially for performing DSP tasks more efficiently. – For example, a 1M-gate Virtex-II™ device has 40 multipliers that can operate at more than 100MHz. In comparison with the DSP this gives 4000M multiplies per second.
Where they Excel
When sample rates grow above a few Mhz, a DSP has to work very hard to transfer the data without any loss. This is because the processor must use shared resources like memory busses, or even the processor core which can be prevented from taking interrupts for some time. An FPGA on the other hand dedicates logic for receiving the data, so can maintain high rates of I/O.
A DSP is optimised for use of external memory, so a large data set can be used in the processing. FPGAs have a limited amount of internal storage so need to operate on smaller data sets. However FPGA modules with external memory can be used to eliminate this restriction.
A DSP is designed to offer simple re-use of the processing units, for example a multiplier used for calculating an FIR can be re-used by another routine that calculates FFTs. This is much more difficult to achieve in an FPGA, but in general there will be more multipliers available in the FPGA.
If a major context switch is required, the DSP can implement this by branching to a new part of the program. In contrast, an FPGA needs to build dedicated resources for each configuration. If the configurations are small, then several can exist in the FPGA at the same time. Larger configurations mean the FPGA needs to be reconfigured – a process which can take some time.
The DSP can take a standard C program and run it. This C code can have a high level of branching and decision making – for example, the protocol stacks of communications systems. This is difficult to implement within an FPGA.
Most signal processing systems start life as a block diagram of some sort. Actually translating the block diagram to the FPGA may well be simpler than converting it to C code for the DSP.
Making a Choice
There are a number of elements to the design of most signal processing systems, not least the expertise and background of the engineers working on the project. These all have an impact on the best choice of implementation. In addition, consider the resources available – in many cases, HERON I/O modules have FPGAs on board. Using these with a DSP processor may provide an ideal split.
As a rough guideline, try answering these questions:
What is the sampling rate of this part of the system? If it is more than a few MHz, FPGA is the natural choice.
Is your system already coded in C? If so, a DSP may implement it directly. It may not be the highest performance solution, but it will be quick to develop.
What is the data rate of the system? If it is more than perhaps 20-30Mbyte/second, then FPGA will handle it better.
How many conditional operations are there? If there are none, FPGA is perfect. If there are many, a software implementation may be better.
Does your system use floating point? If so, this is a factor in favour of the programmable DSP. None of the Xilinx cores support floating point today, although you can construct your own.
Are libraries available for what you want to do? Both DSP & FPGA offer libraries for basic building blocks like FIRs or FFTs. However, more complex components may not be available, and this could sway your decision to one approach or the other.
In reality, most systems are made up of many blocks. Some of those blocks are best implemented in FPGA, others in DSP. Lower sampling rates and increased complexity suit the DSP approach; higher sampling rates, especially combined with rigid, repetitive tasks, suit the FPGA.
海潮
头像被屏蔽
发表于 2006-8-24 23:23:35 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2006-8-25 04:54:48 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-8-25 22:40:56 | 显示全部楼层
FPGA 哈哈
发表于 2006-9-3 17:29:44 | 显示全部楼层
支持一下,希望以后多发点好资料
发表于 2006-9-3 17:30:54 | 显示全部楼层
支持一下,希望以后多发点好资料
发表于 2006-9-3 17:31:26 | 显示全部楼层
支持一下,希望以后多发点好资料
发表于 2006-9-3 17:32:44 | 显示全部楼层
支持一下,希望以后多发点好资料
发表于 2006-9-4 13:08:16 | 显示全部楼层
我现在是用FPGA,不过感觉如果是有除法运算的话,FPGA不好实现
GMT+8, 2025-9-13 14:17 , Processed in 0.029170 second(s), 5 queries , Gzip On, Redis On.
