查看: 12055|回复: 35
[原创] MIXED-SIGNAL AND DSP DESIGN TECHNIQUES
发表于 2004-6-16 19:52:49 | 显示全部楼层 |阅读模式
LBSALE[10]LBSALEMIXED-SIGNAL AND DSP DESIGN TECHNIQUES
SECTION 1
INTRODUCTION
SECTION 2
SAMPLED DATA SYSTEMS
 Discrete Time Sampling of Analog Signals
 ADC and DAC Static Transfer Functions and DC Errors
 AC Errors in Data Converters
 DAC Dynamic Performance
SECTION 3
ADCs FOR DSP APPLICATIONS
 Successive Approximation ADCs
 Sigma-Delta ADCs
 Flash Converters
 Subranging (Pipelined) ADCs
 Bit-Per-Stage (Serial, or Ripple) ADCs
SECTION 4
DACs FOR DSP APPLICATIONS
 DAC Structures
 Low Distortion DAC Architectures
 DAC Logic
 Sigma-Delta DACs
 Direct Digital Synthesis (DDS)
SECTION 5
FAST FOURIER TRANSFORMS
 The Discrete Fourier Transform
 The Fast Fourier Transform
 FFT Hardware Implementation and Benchmarks
 DSP Requirements for Real Time FFT Applications
 Spectral Leakage and Windowing
SECTION 6
DIGITAL FILTERS
 Finite Impulse Response (FIR) Filters
 Infinite Impulse Response (IIR) Filters
 Multirate Filters
 Adaptive Filters
SECTION 7
DSP HARDWARE
 Microcontrollers, Microprocessors, and Digital Signal
Processors (DSPs)
 DSP Requirements
 ADSP-21xx 16-Bit Fixed-Point DSP Core
 Fixed-Point Versus Floating Point
 ADI SHARC® Floating Point DSPs
 ADSP-2116x Single-Instruction, Multiple Data (SIMD)
Core Architecture
 TigerSHARC™: The ADSP-TS001 Static Superscalar
DSP
 DSP Benchmarks
 DSP Evaluation and Development Tools
SECTION 8
INTERFACING TO DSPs
 Parallel Interfacing to DSP Processors: Reading Data
From Memory-Mapped Peripheral ADCs
 Parallel Interfacing to DSP Processors: Writing Data to
Memory-Mapped DACs
 Serial Interfacing to DSP Processors
 Interfacing I/O Ports, Analog Front Ends, and Codecs to
DSPs
 DSP System Interface
SECTION 9
DSP APPLICATIONS
 High Performance Modems for Plain Old Telephone
Service (POTS)
 Remote Access Server (RAS) Modems
 ADSL (Assymetric Digital Subscriber Line)
 Digital Cellular Telephones
 GSM Handset Using SoftFone™ Baseband Processor
and Othello™ Radio
 Analog Cellular Basestations
 Digital Cellular Basestations
 Motor Control
 Codecs and DSPs in Voiceband and Audio Applications
 A Sigma-Delta ADC with Programmable Digital Filter
SECTION 10
HARDWARE DESIGN TECHNIQUES
 Low Voltage Interfaces
 Grounding in Mixed Signal Systems
 Digital Isolation Techniques
 Power Supply Noise Reduction and Filtering
 Dealing with High Speed Logic
INDEX文字
14_102.rar
3.56 MB, 下载次数: 170 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2004-6-17 01:13:56 | 显示全部楼层
xiexie !!
发表于 2004-7-19 15:47:58 | 显示全部楼层
谢谢,正要搞ADSP
发表于 2004-12-29 15:49:01 | 显示全部楼层
我也搞dsp但是是指令的!
顶!
发表于 2005-1-6 13:01:16 | 显示全部楼层
hao
发表于 2005-3-9 23:34:26 | 显示全部楼层
3Q
发表于 2005-4-22 12:04:32 | 显示全部楼层
So perfect, thanks .....
发表于 2005-4-23 22:01:55 | 显示全部楼层
thanks
发表于 2005-5-6 22:34:25 | 显示全部楼层
3Q
发表于 2005-7-16 16:08:17 | 显示全部楼层
多谢多谢
GMT+8, 2025-12-28 05:38 , Processed in 0.025054 second(s), 10 queries , Gzip On, Redis On.
