查看: 2869|回复: 6
Analog Circuit Design:
发表于 2009-1-12 07:00:08 | 显示全部楼层 |阅读模式
        Analog Circuit Design: Volt Electronics; Mixed-Mode Systems; Low-Noise and RF Power Amplifiers for Telecommunication
                                        por: Johan H. Huijsing, Rudy J. van de Plassche, Willy M.C. Sansen
                                        [size=95%]en
                                        0792384008  9780792384007
LINK FOR DOWNLOAD :  http://ifile.it/drjt51b
[size=120%]Analog Circuit Design: Volt Electronics; Mixed-Mode Systems; Low-Noise and RF Power Amplifiers for Telecommunication
By Johan H. Huijsing, Rudy J. van de Plassche, Willy M.C. Sansen
  •                  Publisher:                                   Springer
  •                  Number Of Pages:                                   428
  •                  Publication Date:                                   1998-12-31
  •                  ISBN-10 / ASIN:                                   0792384008
  •                  ISBN-13 / EAN:                                   9780792384007
  •                  Binding:                                   Hardcover
Product Description:
This volume of Analog Circuit Design concentrates on three topics:Volt Electronics; Design and Implementation of Mixed-Mode Systems;Low-Noise and RF Power Amplifiers for Telecommunication. The bookcomprises six papers on each topic written by internationallyrecognised experts. These papers are tutorial in nature and togethermake a substantial contribution to improving the design of analogcircuits. The book is divided into three parts: Part I, VoltElectronics, presents some of the circuit design challenges which arehaving to be met as the need for more electronics on a chip forcessmaller transistor dimensions, and thus lower breakdown voltages. Thepapers cover techniques for 1-Volt electronics. Part II, Design andImplementation of Mixed-Mode Systems, deals with the various problemsthat are encountered in mixed analog-digital design. In the future, allintegrated circuits are bound to contain both digital and analogsub-blocks. Problems such as substrate bounce and other substratecoupling effects cause deterioration in signal integrity. Both aspectsof mixed-signal design have been addressed in this section and itillustrates that careful layout techniques embedded in a hierarchicaldesign methodology can allow us to cope with most of the challengespresented by mixed analog-digital design. Part III, Low-noise and RFPower Amplifiers for Telecommunication, focuses on telecommunicationssystems. In these systems low-noise amplifiers are front-ends ofreceiver designs. At the transmitter part a high-performance,high-efficiency power amplifier is a critical design. Examples of bothsystem parts are described in this section. Analog Circuit Design is anessential reference source for analog design engineers and researcherswishing to keep abreast with the latest developments in the field. Thetutorial nature of the contributions also makes it suitable for use inan advanced course.
发表于 2010-9-28 16:56:04 | 显示全部楼层
THANK YOU
发表于 2011-1-16 17:20:02 | 显示全部楼层
Huijsing and Sansen, big niu
发表于 2011-1-16 17:27:31 | 显示全部楼层
thanks for sharing~
发表于 2014-12-31 13:57:13 | 显示全部楼层
very good material
发表于 2016-11-19 04:16:00 | 显示全部楼层
thanks a lot
发表于 2019-7-17 10:53:19 | 显示全部楼层
thanks for sharing!
GMT+8, 2025-12-16 07:45 , Processed in 0.024165 second(s), 7 queries , Gzip On, Redis On.
