查看: 9725|回复: 36
FM Transmitter and Receiver
发表于 2006-6-6 12:23:42 | 显示全部楼层 |阅读模式
FM Transmitter and Receiver design
7_1129.pdf
344.17 KB, 下载次数: 319 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-8-2 03:17:03 | 显示全部楼层
謝謝分享!
发表于 2006-10-17 00:07:15 | 显示全部楼层
谢谢。。。
发表于 2006-10-17 18:41:59 | 显示全部楼层
这是一篇9页纸的报告,全称是:Design and Construction of FM Transmitter and Receiver。
谢谢分享。
发表于 2006-10-23 00:57:36 | 显示全部楼层
thanks for your information....
thanks,,,
发表于 2007-4-25 14:05:54 | 显示全部楼层
look,look
发表于 2007-10-15 20:39:58 | 显示全部楼层
是篇文章。
Design and Construction of FM Transmitter and Receiver Final Report David Chen
Abstract: Our FM transmitter and receiver are built with discrete analog components and integrated on two circuit boards. The modulation scheme uses a superheterodyne setup, in which the intermediate carrier is at 300-kHz and the transmission carrier is at 24.3-MHz. Using 711-mW of DC power, the transmitter outputs a 5-dBm signal centered at 24.3-MHz with 100-kHz bandwidth. Using about half as much power, around 342-mW, the receiver can detect incoming signals at powers as low as -110 dBm. This receptivity level translates to successful audio reception at distances of almost 2-km from the transmitting antenna atop Packard.
发表于 2007-11-7 02:28:01 | 显示全部楼层
thanks for your information...............
thanks..............
发表于 2007-12-2 18:50:38 | 显示全部楼层
发表于 2008-1-14 19:31:23 | 显示全部楼层
可惜沒有更好的FM文章
GMT+8, 2025-12-25 01:52 , Processed in 0.023898 second(s), 9 queries , Gzip On, Redis On.
