查看: 3618|回复: 2
Tektronıx concepts !!! Help to fınd other fıles !!!
发表于 2009-1-11 09:36:10 | 显示全部楼层 |阅读模式
WORK MADE FOR : Tektronix "Concepts" Series Books
I am still looking for paper copies of titles marked in Bold below; Iwill accept extra copies of any of the others in trade for manuals, orbuy them if the price is right.
David DiGiacomo
david@slack.com
Thanks to Fred E. Davis, Mark Kahrs, Andrew Mayrs, Cliff Schuring, andJohn Shriver for assistance in compiling this information.
Circuit Concepts
062-1144-00        Horizontal Amplifier Circuits        Kenneth L. Arthur
062-1460-00        Oscilloscope Camera Concepts        Will Marsh
062-1172-00        Sampling Oscilloscope Circuits        John Mulvey
062-1055-00        Spectrum Analyzer Circuits        Morris Engelson
062-1145-00        Vertical Amplifier Circuits        Bob Orwiler
Measurement Concepts
Part No.        Title        Author        Contents        Scan        Scan Source
062-1106-00        Automated Testing Systems        Leonard W. Bell
062-1247-00        Biophysical Measurements        Peter Strong
062-1074-00        Engine Analysis        Jim Thurman        contents
062-1120-00        Probe Measurements        Walter E. McAbel
062-1070-00        Spectrum Analyzer Measurements        Dan Welch
062-1334-00        Spectrum Analyzer Measurements, Theory and Practice        Morris Engelson
062-1064-00        Television Systems Measurements        Gerald A. Eastman
062-1246-00        Transducer Measurements        Kenneth Arthur
   1. Introduction
   2. Radiation and Light
   3. Recording Materials and Processes
   4. Photographic Optics
   5. Cathode-Ray Tubes
   6. Cameras
   7. Features of Oscilloscope Cameras
Oscilloscope Cathode-Ray Tubes
   1. Introduction
   2. Electron Optics
   3. The Triode Section
   4. Unblanking
   5. Focus and Astigmatism Lens
   6. The Deflection System
   7. Acceleration Schemes
   8. Space Charge Repulsion and Trace Width
   9. Phosphors
  10. Human Eye Response
  11. Luminance Characteristics of Phosphors
  12. Spectral Response
  13. Writing Speed
  14. Phosphor Burning
  15. Aluminized Tubes
  16. Light Filters
  17. Graticles
  18. Trace Alignment
  19. Dual Beam
  20. Dual Gun
Digital Concepts
Digital Concepts
   1. Introduction
   2. The Binary Number System
   3. Boolean Algebra
   4. NAND Gate, NOR Gate, and Flipflop
   5. Implementing Logic Functions
   6. Implementing Logic Circuits Using Integrated Circuits
   7. Counting Circuits
   8. Counter Readout Circuits
   1. Basic Function and Design
   2. Horizontal Amplifier
   3. Typical Circuit Configurations
   4. External Horizontal Preamplifiers
Power Supply Circuits
   1. Rectifiers and Filters
   2. Voltage Regulators
   3. The PRLV Power Supply
   4. AC-DC Power Supplies
   5. High-Voltage Power Supplies
   6. Power Supply Hardware
Oscilloscope Probe Circuits
   1. Introduction
   2. Passive Voltage Probes
   3. Z0 Probes
   4. Active Voltage Probes
   5. Current Probes
   6. Differential Probes
   7. High Voltage Probes
   1. Introduction to Sampling Principles
   2. Basic Circuit Functions and Relationships
   3. Sampling, Amplifying and Holding Circuits
   4. Ramp Triggering and Ramp Delay Circuits
   5. Sequential Mode Timing and Strobe Delay Circuits
   6. Random Mode Circuits
   1. Background Material
   2. Components and Subassemblies
   3. Filters
   4. Amplifiers
   5. Mixers
   6. Oscillators
   7. RF Attenuators
Sweep Generator Circuits
   1. Sawtooth Waveform Characteristics
   2. The Gated-Clamp-Tube Generator
   3. The Bootstrap Sweep Generator
   4. The Miller Integrator Sweep Generator
   5. Sweep Generator Control Circuits
Trigger Circuits
Trigger Circuits
   1. Introduction
   2. Trigger Circuits
   3. Input Triggering Signals
   4. Pulse Generators
   5. Delaying and Delayed Sweeps
   6. Triggered Delayed Sweeps
   1. Vertical Amplifiers
   2. Input Circuits and Compensated Attenuators
   3. Followers
   4. Transmission Lines
   5. Single-ended Amplifiers
   6. Differential Amplifier Family
   7. Fedback Amplifiers
   8. Unijunction Transistors
   9. Thyristors (SCRs) and Other PNPN Devices
  10. Signal Diodes and Rectifying Diodes
  11. Zener Diodes
  12. Tunnel Diodes and Back Diodes
   1. Introduction to Tektronix Systems
         1. System Measuring Capabilities and Organization
   2. The Memory and Control Block
         2. Data Disc
         3. Punched Tape - Tape reader and tape perforation
         4. Type 240 Program control unit and type 250 Auxilary Program Unit
         5. Type 241 Programmer Unit
   3. The Measure Block
         6. Review of Sampling Theory
         7. The Type R568 Oscilloscope, type 3S6 Vertical and 3T6 Sweep
         8. The Type 230 Digital Unit
         9. Testing Systems Options
   4. The Stimulus Block
        10. The Type R116 Programmable Pulse Generator
        11. The Type R293 Programmable Pulse Generator and Power Supply
        12. Programmable power supplies
   5. The Fixture Block
        13. Discussion of fixturing and problems
   6. Recap discussion
        14. Types of systems offered
Engine Analysis Measurements
   1. Ignition Systems
   2. Ignition Waveform Analysis
   3. Magnetic Transducer
   4. Rotational Function Generator
   5. Vibration Transducer
   6. Pressure Transducer
Information Display Concepts
   1. Introduction
   2. Local computer peripherals
   3. Time Sharing
   4. Programming
   5. Digital Data Transmission
   6. Computer Display Terminals
   7. Terminal Output Devices
   8. Digital-to-Analog and Analog-to-Digital Converters and Vector and Character Generators
   9. Characteristics and Specifications of Direct-View Bistable Storage tubes
  10. Display-unit Circuit Design Considerations
Probe Measurements
   1. Passive Probes
   2. Active Probes
   3. Current Probes
Semiconductor Device Measurements
   1. Bipolar Transistors
   2. Field Effect Transistors
   3. Unijunction Transistors
   4. Thyristors (SCRs) and Other PNPN Devices
   5. Signal Diodes and Rectifying Diodes
   6. Zener Diodes
   7. Tunnel Diodes and Back Diodes
   1. Concept of RF Spectrum Tuning
   2. RF Modulation Systems
   3. Spectrum Analyzer Terms
   4. Spectrum Analyzer Characteristics and Their Relationships
   5. Spectrum Analyzer Function Considerations
   6. CW Signal Measurements
   7. Amplitude-Modulation Measurements
   8. Frequency Modulation Measurements
   9. Single-Sideband Measurements
  10. Pulsed RF Carrier Measurements
  11. Swept Frequency Measurements
  12. Fluid Velocity Measurements
  13. Waveform Analysis
   1. Spectrum Analyzers
   2. Spectrum Theory
   3. Fourier Analysis
   4. Modulation Theory
   5. The Sweeping-Signal Spectrum Analyzer
   6. The Measurement Problem
   7. Amplitude Modulation
   9. Pulsed RF
  10. Miscellaneous Applications
  11. Definition of Terms
Storage Cathode-Ray Tubes and Circuits
   1. Basic Principles of Direct-Viewing Storage Tubes
   2. Charging and Bistability
   3. Bistability in Multiple Targets and Dielectric Targets
   4. Simplified Bistable Storage Tubes
   5. Characteristics
   6. Transmission Storage Tubes
   7. Basic Storage Circuits
   1. Camera
   2. Television Tape Recorder
   3. Telecine
   4. Signal Switching
   5. Transmitter
   6. Video Distribution System
   7. Components of Video Waveform
   8. Measurements Requirements
   9. Analysis of Video Transients
  10. Color-Bar Waveform Analysis
  11. Multiburst Test Waveform
  12. Modulated Stairstep Test Waveform
  13. Picture-Waveform Analysis
Television Waveform Processing Circuits
   1. Introduction
   2. Basic Television Systems Requirements
   3. Television Waveform Components
   4. DC Levels in Video Systems
   5. DC Restorer Circuits
   6. Feedback DC Restorer Circuits
   7. Waveform Synchronization
   8. Synchronizing Pulse Separation
   9. Synchronizing Pulse Processing
  10. Basic Color Concepts
  11. Color Television System Requirements
  12. Color Modulation and Demodulation
  13. Chrominance Subcarrier Regeneration
  14. Chrominance Synchronizing
  15. Subcarrier Processing Circuits
  16. Circuit Concepts in the Functional Block System
Time-Domain Reflectometry Measurements
   1. Transmission-Line Basics
   2. Pulse Response Versus Frequency Response of Coaxial Cables
   3. Basics of TDR
   4. Time and Amplitude Resolution Related to the Form of TDR System Hookup
   5. TDR applications
   6. A Comparision of Sinewave Testing and Voltage Step-Function Testing of Coaxial Transmission Lines
   1. Concepts of Quantitative Measurement
   2. Principles of Transducer Operation
   3. The Measurand
   4. Transducer Instrumentation Systems
   5. Tektronix Transducer Instrumentation
   6. Practical Applications
发表于 2010-4-12 21:21:46 | 显示全部楼层
thanks
发表于 2010-10-30 20:01:52 | 显示全部楼层
我是初學者,沒有經驗,謝謝大大提供資訊,網路分享,迅速吸收,受用無窮
GMT+8, 2025-12-14 23:18 , Processed in 0.091564 second(s), 5 queries , Gzip On, Redis On.
