查看: 6585|回复: 30
Wireless Digital Communications: Design and Theory
发表于 2009-1-7 20:06:37 | 显示全部楼层 |阅读模式
[求书]
Tom McDermott, Wireless Digital Communications: Design and Theory, Tucson Amateur Packet Radio Corporation, Tucson,Arizona, 1996.
[ 本帖最后由 etop1 于 2009-1-7 20:07 编辑 ]
cover
cover
WDC.DAT.N5EG.pdf
292.26 KB, 下载次数: 71 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Table of Contents and Information
 楼主| 发表于 2009-1-7 20:08:51 | 显示全部楼层
Table of Contents
Chapter 1 - Introduction
  Definition of Information
  Source Entropy
  Fundamental Data Capacity
  Signal to Noise ratio - Eb/No
  Block Diagram of the Communication System
  Review / Definition of Some Key Concepts
  Eye Pattern
  Signal Constellation Diagram
  Chapter 1 - References
Chapter 2 - Additive White Gaussian Noise (AWGN)
  Definition of AWGN Noise
  Gaussian Distribution
  Calculating the BER given AWGN
  Generating a BER Curve
  Relation of Power Spectrum and AWGN
  Computing Noise and Signal Magnitudes
  Chapter 2 - References
Chapter 3 - Antipodal, Orthogonal, and Non-orthogonal Signaling
  Antipodal Signaling
  Orthogonal Signaling
  Analysis of FSK signaling
  Orthogonal Waveforms
  Orthogonal FSK Demodulators
  Chapter 3 - References
Chapter 4 - Carrier Transmission
  FSK - Frequency Shift Keying
  FFSK - Fast Frequency Shift Keying
  mFSK - m-ary FSK
  PSK - Phase Shift Keying
  mPSK - m-ary Phase Shift Keying
  OQPSK - Offset QPSK
  Received Phase Ambiguity
  Performance of PSK modulation in the presence of AWGN
  ASK - Amplitude Shift Keying
  MSK - Minimum Shift Keying
  OFDM - Orthogonal Frequency Division Multiplexing
  OFDM based on m-ary FSK
  OFDM based on ASK
  AFSK - Audio Frequency Shift Keying
  Summary
  Chapter 4 - Reference
Chapter 5 - Frequency and Impulse Response of Optimum Modem Filters
  Optimum filter criteria
  Raised-Cosine Filter Responses
  Filter Response Partitioning
  Filter Impulse Response
  Filter Response to an Isolated Data Bit
  Eye Pattern Generation
  Equivalent Noise Bandwidth
  Some Frequency Response Defects
  Impulse-Response Length Truncation
  Detailed Step-by-Step Procedure
  Dolph-Chebychev Transmit Pulses
  Chapter 5 - Reference
Chapter 6 - Matched Filters
  Matched filter for Rectangular Pulses
  Matched filter for Square-Root Raised-Cosine Transmit Pulses
  Use of the Matched Filter Symmetry to Equalize a Channel
  Chapter 6 - Reference
Chapter 7 - Data Codes
  Basic Data Codes
  DC-Balance (One's Density) of the Code
  Scrambling
  Forward Error Correcting (FEC) Codes
  Linear Block Codes
  AWGN Performance of Linear Block Codes
  Statistical Performance of Linear Block Codes
  Other Properties of FEC Codes
  Interleaving the Codewords
  Golay Codes
  Longer Codes
  Reed-Solomon Codes
  Convolutional Codes
  Decoding the Convolutional Code
  Convolutional Decoders
  Viterbi's Algorithm
  Summary of Viterbi Decoder
  Chapter 7 - Reference
Chapter 8 - Data Slicer and the Slicing Level
  Slicing Level Determination
  Source Statistics
  Non-Scrambled Data
  NRZI-Coded HDLC Calculations
  Scrambled Data Calculations
  Binomial Distribution
  Fixed Slicing-Level Methods
  DSP-Based Slicing-Level Determination
Chapter 9 - Clock Recovery
  The Importance of Accurate Clock Position
  Methods to Recover the Clock
  Closed-Loop Clock Recovery
  Clock Recovery Filters
  Filter Transfer Function
  Modulation-Based Clock Recovery
  Chapter 9 - Reference
Chapter 10 - Carrier Recovery
  Deriving a Carrier Reference
  Carrier Generation by Rectification
  Carrier Generation by Multiplication
  Other Methods of Carrier Generation
  2PSK Carrier Recovery - Costas Loop
  Chapter 10 - Reference
Chapter 11 - Phase Locked Loops for Carrier and Clock Recovery
  Closed Loop Response
  Open Loop Response
  Lead Lag Filter
  Higher Order Loop Filter
  Parasitic Poles
  PLL Loop Lock time
  PLL Noise Bandwidth
  Types of Phase Detectors, Lock-in Range
  Control Loop Dynamic Range
  Chapter 11 - Reference
Chapter 12 - Frame Alignment and Data Carrier Detect
  General Data Carrier Detect (DCD) Acquisition
  DCD and Frame Alignment based on Message Content
  Median Time to False Frame Declaration
  Maximum Average Reframe Time
  Going Out of Frame
  Other Message Content
  Framing on Short Transmissions
  Chapter 12 - Reference
Chapter 13 - Propagation Channel Models
  VHF and UHF Channel Models
  Minimum-Phase and Non-Minimum-Phase Fades
  Rayleigh fading
  Circular Polarization
  Wideband Data Channels
  Rules of Thumb
  HF Channel models
  Signaling Rate Bounds
  HF Channel Simulation
  Coefficient Properties
  Bit Error Rate Performance of Rayleigh Faded Path
  Diversity Reception
  Approaches to HF Modem Design
  RTTY - Live With the Errors
  AMTOR - Simple Error Detection and Re-transmission
  AX.25 Packet Transmission - 300 baud HF
  More Recent Developments
  GTOR
  Pactor II
  Clover II
  Future Improvements
  Chapter 13 - Reference
Chapter 14 - Automatic Request for Repeat (ARQ)
  Simple ARQ
  Hybrid ARQ
  Performance of ARQ
Chapter 15 - Testing Considerations
  Bit Error Rate vs. Received Signal Level
  Baseband BER Test
  Butterworth Calibration Filter
  Radio Characterization for Data
  Radio-based Test
  FSK - Transmitter Characterization
  Other Transmitter Characterization
  FSK - Receiver Characterization
  System Characterization
  Theoretical Eb/No vs. Received Signal Level (RSL)
  Pseudo-Level Error Detection Margin
  Adjustment Aid - 'Click' box
  Bit Error Rate Test Statistics
  Chapter 15 - Reference
Appendix A - Some Useful Probability Distributions
  A.1 Probability of Events.
  A.2 Histograms, Probability Density, Cumulative Density
  A.3 Uniform Distribution
  A.4 Binomial Distribution
  A.5 Gaussian Distribution
  A.6 Poisson Distribution
  A.7 Rayleigh Distribution
Appendix B - Pseudo-Random Binary Sequence (PRBS) Generators
  B.1 Properties of a PRBS
  B.2 Construction of the PRBS Generator.
  B.3 Autocorrelation Properties
  B.4 Self Synchronization
  B.5 Self Synchronous Scrambler and Descrambler
  B.6 Binary Polynomial Arithmetic
  Appendix B - Reference
Appendix C - Discrete Fourier and Inverse Discrete Fourier Transforms & Complex
Numbers
  C.1 The Fourier Transform and the Impulse Response
  C.2 Complex Number Representation
  C.3 Description of a Signal using Complex Notation
  C.4 Complex Conjugate
  C.5 Discrete Fourier Transform
  C.6 Power Spectral Density (PSD)
  C.7 Symmetry Requirement for Frequency Response
  Appendix C - Reference
Appendix D - Correlation, Convolution, and Laplace Notation for Filters
  D.1 Convolution and Multiplication
  D.2 Convolution
  D.3 Frequency and Impulse Response
  D.4 Correlation
  D.5 Cross Correlation
  D.6 Autocorrelation
  D.7 Complex Signals
  D.8 Laplace Notation for Complex numbers
  Appendix D - Reference
  TAPR Information
  Index
 楼主| 发表于 2009-1-7 20:11:56 | 显示全部楼层
Preface
Amateur radio communication has progressed in many ways since its beginning in the early 1900's. General communications progressing from spark to CW and voice from AM to FM and SSB. Similarly, data communications as a mode of amateur communications has progressed from using on-off keying (OOK) to FSK, and from RTTY to more modern modes of communications (synchronous and error-correcting).
There has been a lack of good technical background material in amateur radio literature on the principles and design of synchronous digital modems.
The wealth and quality of literature in the professional world in the subject area is astounding, but much of it may not be readily accessible to the radio amateur, whether for reasons of advanced mathematics, or simple lack of
availability.
In writing this book, the aim has been to bring a concise group of topics covering a broad spectrum of amateur synchronous digital communications subjects to print in one place, and to make it readily accessible to the radio amateur.
This text aims to present the information in a clear and straight-forward manner, with the maximum use of graphical and computer-assisted aids, and with a minimum of rigorous mathematical theory. However, digital communications deals with the application and solution of statistical phenomenon, and a minimum background is necessary. Where practical, the appendices provide short summaries of some of the important mathematical concepts that will be needed in understanding certain areas.
Overall, the field of digital communications could be generally broken into two categories: bandwidth-limited communications and power-limited communications.
Much of the professional literature focuses on the former, while in practice the amateur is many times concerned with the latter. This text focuses more on the subject of power-limited communications and emphasizes, through examples, the circuits and problems of the latter category of applications.
With time and the increasingly more crowded HF bands, however, the radio amateur will adopt more sophisticated data modems, offering higher throughput and narrower bandwidth operation under the demanding propagation conditions of the HF medium. This trend has already started and should accelerate as the cost of technology, particularly Digital Signal Processing, continues to decrease. So, this text includes information on the subject areas of DSP-based modem filters, and on forward-error-correcting codes, whose use by the radio amateur will become dominant within a few short years. While the data rate of VHF and UHF communications will increase, it is expected that, for the radio amateur, these will remain power-limited applications for some time.
In the preparation of this text, I have relied on the study of a number of exceptionally well written textbooks, and to the IEEE literature in the area, and these should be consulted whenever more depth or broader interest is desired. I would like to thank the reviewers of the text for many helpful comments, related both to the readability of the material, ...
 楼主| 发表于 2009-1-7 20:26:51 | 显示全部楼层
Download book disk  and Information
http://www.tapr.org/pub_wdcdat.html
发表于 2009-1-11 22:14:35 | 显示全部楼层
同求此书,希望有书者共享,大家共同进步
促进学术交流
发表于 2009-1-30 23:00:46 | 显示全部楼层
thanks
发表于 2009-1-31 22:17:44 | 显示全部楼层
thanks a lot
发表于 2009-2-5 02:42:53 | 显示全部楼层
Thanks a you so much! I like it.
发表于 2009-2-7 18:23:54 | 显示全部楼层
发表于 2009-2-7 18:35:59 | 显示全部楼层
五毒透骨贴痛乐贴完全是假冒伪劣品
新华社太原12月2日专电(记者刘翔霄)记者2日从太原市食品药品监督管理局了解到,20种冒充药品的保健用品日前被依法查处。药监部门在向社会发布公告提醒消费者注意的同时,已要求各药品经营企业立即进行自查,停止销售类似产品。
      太原市药监局局长刘建国告诉记者,被查处的保健用品在产品包装上非法标注适用疾病名称和功能主治,标示或暗示治疗、缓解疾病症状的作用,使其具有了药品的功效。经查实,这些保健用品大多未经审批和注册,所标示文号有的已被注销,有的纯属编造,有的系盗用。这些假冒药品的保健用品严重损害消费者健康权益,扰乱药品市场秩序。
      据介绍,这些被查处保健用品的产品名称、标示批准文号、标示生产企业分别如下:
      五毒透骨贴痛乐贴,陕食药监健用字04010008,生产企业:西安康诺药业科技有限公司;举报(全系统举报电话) 陕西省药监局:029-85361310 jcc@sxyj.gov.cn 西安市药监局:029-5533311
GMT+8, 2025-12-23 14:14 , Processed in 0.039525 second(s), 9 queries , Gzip On, Redis On.
