查看: 4384|回复: 2
cadence IC610安装过程中的warn信息
发表于 2008-12-23 14:51:58 | 显示全部楼层 |阅读模式
IC610在安装过程中,出现了如下警告信息,哪位大侠遇到过类似问题?给小弟指点一下,在此多谢了......
Initializing InstallScape using JVM at /home/lhg/installscape/iscape/runtime/LNX86/bin/java. This might take some time...
Warning: translation table syntax error: Unknown keysym name:  osfActivate
Warning: ... found while parsing ':<Key>osfActivate:            ManagerParentActivate()'
Warning: String to TranslationTable conversion encountered errors
Warning: translation table syntax error: Unknown keysym name:  osfBeginLine
Warning: ... found while parsing ':<Key>osfBeginLine:           ManagerGadgetTraverseHome()'
Warning: translation table syntax error: Unknown keysym name:  osfHelp
Warning: ... found while parsing ':<Key>osfHelp:                        ManagerGadgetHelp()'
Warning: ... found while parsing ':<Key>osfActivate:    DrawingAreaInput() ManagerParentActivate()'
Warning: translation table syntax error: Unknown keysym name:  osfUp
Warning: ... found while parsing ':<Key>osfUp:          DrawingAreaInput() ManagerGadgetTraverseUp()'
Warning: ... found while parsing ':<Key>osfActivate:    PrimitiveParentActivate()'
Warning: ... found while parsing ':<Key>osfHelp:                Help()'
Warning: translation table syntax error: Unknown keysym name:  osfCancel
Warning: ... found while parsing ':<Key>osfCancel:      MenuEscape()'
Warning: translation table syntax error: Unknown keysym name:  osfSelect
Warning: ... found while parsing ':<Key>osfSelect:      ArmAndActivate()'
Warning: ... found while parsing '<Key>osfCancel:                       MenuEscape()'
Warning: ... found while parsing ':<Key>osfSelect:      ManagerGadgetSelect()'
Warning: ... found while parsing ':<Key>osfSelect:      MenuBarGadgetSelect()'
Warning: ... found while parsing ':<Key>osfActivate:    ManagerParentActivate()'Warning: String to TranslationTable conversion encountered errors
Warning: ... found while parsing ':<Key>osfHelp:                MenuHelp()'
Warning: translation table syntax error: Unknown keysym name:  osfPrimaryPaste
Warning: ... found while parsing ':m <Key>osfPrimaryPaste:cut-primary()'
 楼主| 发表于 2009-1-2 21:37:58 | 显示全部楼层
已解决,添加export XKEYSYMDB=/usr/share/X11/XKeysymDB,,,,OK!
发表于 2011-4-26 10:30:09 | 显示全部楼层
我的是显示问题,在/etc/X11/xorg.conf中填了三行语句,icfb就可以正常使用,但是重启后,Centos5.6的任务栏 就没东西了,只能打开终端
GMT+8, 2025-12-30 03:35 , Processed in 0.017638 second(s), 7 queries , Gzip On, Redis On.
