查看: 5423|回复: 17
[EBOOK]Artech House,Gsm Networks-Protocols,Terminology And Implementation[已修复
发表于 2004-7-3 12:00:22 | 显示全部楼层 |阅读模式
[这个贴子最后由一声叹息在 2004/09/20 09:49am 第 2 次编辑]
by Gunnar Heine
This practical book provides an extremely comprehensive, up-to-date, and easy-to-understand treatment of the entire GSM network and the signaling methods of its terrestrial interfaces. You learn how to analyze network problems, what measurements you have to take to solve them, and where in a scenario you will find the desired information or parameter. The book introduces you to all the interfaces between the GSM subsystems, starting with the Abis- and Air- Interface and continuing on to VLR’s, HLR’s and MSC’s within the Network Switching Subsystem (NSS). You learn about the various signaling standards or methods used in GSM, including TCAP and MAP and how to apply this knowledge when working with GSM networks.
Other subject areas related to Gsm Networks: Protocols, Terminology, and Implementation (Artech House Mobile Communications Library.) (possibly beyond the scope of this Communications Systems Glossary) include: Engineering - Industrial, Global system for mobile commu, Cellular Communication Technology, Communication Networks, Technology & Industrial Arts, Technology, Telecommunications, Engineering - Electrical & Electronic.
TABLE OF CONTENTS
Introduction — About This Book
Mobile Radio
Global System for Mobile Communication (GSM)
General
What Is Signaling? Legend
The Mobile Station (MS) and the Subscriber Identity Module (SIM) — The Subscriber Identity Module (SIM)
The SIMa Database
The Advantage for the Customer
The Mobile Station
The Base Station Subsystem (BSS) — The Base Transceiver Station (BTS)
The Base Station Controller (BSC)
The Transcoding Rate and Adaptation Unit (TRAU)
The Network Switching Subsystem (NSS) — Home Location Register (HLR) and Authentication Center (AuC)
The Visitor Location Register (VLR)
The Mobile-Services Switching Center (MSC)
The Equipment Identity Register (EIR)
The OSI Reference Model — Reasons for Standardization
The Transformation into the OSI Reference Model
Data Types of the OSI Reference Model
Information Processing in the OSI Reference Model
The Benefit from the OSI Reference Model
The Seven Layers of the OSI Reference Model
Difficulties Comprehending This Model
The Abis-Interface — Channel Configuration
Options for Connecting a BTS to a BSC
Signaling on the Abis-Interface
Bringing the Abis-Interface into Operation
The Air Interface in GSM — The Structure of the A-Interface
Physical vs
Logical Channels
Logical Channels
Interleaving
Signaling on the Air-Interface
The Signaling System Number 7 (SS7) — The SS7 Network
The Message Transfer Part (MTP)
The Message Types of SS7
Addressing and Routing of Messages
Error Detection and Error Correction
SS7 Network Management and Test
The SCCP (Signaling Connection Control Part) — The Tasks of the SCCP
The SCCP Message Format
The SCCP Messages
The Basics of an SCCP Connection
The A Interface — General
Dimensioning
Signaling on the A-Interface
Transaction Capabilities and Mobile Application Part (TCAP, MAP) — TCAP (Transaction Capabilities Application Part)
MAP (Mobile Application Part)
Scenarios — Location Update
Equipment Check
The Mobile Originating Call (MOC)
The Mobile Terminating Call (MTC)
Handover
Quality of Service (QoS) — Test Equipment
Signaling Analysis in GSM
Tips and Tricks
Where To Find What Parameter in the Trace File
Error Analysis on the Abis and A-Interface
7_353.rar
5.17 MB, 下载次数: 159 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2004-7-3 12:01:46 | 显示全部楼层
LBHIDDEN[0]LBHIDDENGsm Networks-Protocols,Terminology And Implementation
发表于 2004-9-15 20:16:16 | 显示全部楼层
No
发表于 2004-9-20 08:39:50 | 显示全部楼层
怎么没有附件呢?
 楼主| 发表于 2004-9-20 09:34:13 | 显示全部楼层
附件原本是有的,现在丢失了,请坛主帮助解决。
发表于 2004-9-20 11:16:14 | 显示全部楼层
怎么又有了?
 楼主| 发表于 2004-9-20 11:18:30 | 显示全部楼层
好象是一声叹息斑竹帮助修复了。谢谢斑竹和坛主!
发表于 2004-9-20 11:42:32 | 显示全部楼层
请问一声叹息你是怎么修复的?
发表于 2004-9-20 12:13:54 | 显示全部楼层
下面引用由jackzhang2004/09/20 11:42am 发表的内容:
请问一声叹息你是怎么修复的?
呵呵,重新上传了一遍。
发表于 2004-9-20 13:26:29 | 显示全部楼层
我检查了一下服务器,发现确实有一些上传的附件没有了,所以可能还是不知道谁给误删除了
GMT+8, 2025-12-16 03:51 , Processed in 0.022800 second(s), 11 queries , Gzip On, Redis On.
