查看: 45301|回复: 250
121 ADC paper
发表于 2008-11-27 19:14:40 | 显示全部楼层 |阅读模式
2008-07-21  13:15         2,532,613 1.5GSPS 4-bit flash ADC using 0.18?m CMOS.pdf
2008-07-21  11:34           498,636 12-Bits 50 MHz Pipelined Low-Voltage ADC Design.pdf
2008-07-21  11:35           600,517 1V 10-bit successive approximation ADC for low power biomedical applications.pdf
2008-07-21  19:11           533,385 20mW, 125 Msps, 10 bit Pipelined ADC in 65nm Standard Digital CMOS Process.pdf
2008-07-21  19:14           602,667 A 0.05-mm2 110-μW 10-b self-calibrating successive approximation ADC core in 0.18 CMOS.pdf
2008-07-21  19:33         2,237,282 A 0.5V 8bit 10Msps Pipelined ADC in 90nm CMOS.pdf
2008-07-21  20:10         2,355,198 A 0.8V 10b 8OMSs 6.5mW Pipelined ADC with Regulated Overdrive Voltage Biasing.pdf
2008-07-21  13:26           454,128 A 0.9-V 10-bit 100-MSamples pipelined ADC using switched-RC and opamp sharing techniques.pdf
2008-07-21  13:17           166,108 A 0.9V 10-bit 100 MSs switched-RC pipelined ADC without using a front-end SH in 90nm CMOS.pdf
2008-07-21  13:23           626,335 A 1-GSs CMOS 6-bit flash ADC with an offset calibrating method.pdf
2008-07-21  18:55           805,398 A 1.2V 200-MSs 10-bit folding and interpolating ADC in 0.13-μm CMOS.pdf
2008-07-21  13:49         1,686,471 A 1.2V 4.5mW 10b 100MSs Pipeline ADC in a 65nm CMOS.pdf
2008-07-21  20:18         4,395,956 A 1.5MSs 6-bit ADC with 0.5V supply.pdf
2008-07-21  19:08           273,272 A 1.8V 10b 210MSs CMOS Pipelined ADC Featuring 86dB SFDR without Calibration.pdf
2008-07-21  19:22         1,652,857 A 1.8V 36-mW 11-bit 80MSs pipelined ADC using capacitor and opamp sharing.pdf
2008-07-21  13:13           365,946 A 10-BIT 100MSs pipelined ADC IN 0.18μm CMOS technology.pdf
2008-07-21  14:00         1,564,603 A 10-Bit 50-MSPS Pipelined CMOS ADC.pdf
2008-07-21  20:05           328,336 A 10-bit 500-MSs 124-mW Subranging Folding ADC in 0.13 CMOS.pdf
2008-07-21  13:20           190,194 A 10-bit 8.3MSs switched-current successive approximation ADC for column-parallel imagers.pdf
2008-07-21  13:30           573,692 A 10-bit, 1.8-GSs Time-Interleaved Pipeline ADC.pdf
2008-07-21  13:26           789,687 A 100MSs recycling 2-step ADC embedding programmable gain amplification for DVB satellite.pdf
2008-07-21  19:53         3,415,005 A 10b 160MSs 84mW 1V Subranging ADC in 90nm CMOS.pdf
2008-07-21  20:19           215,390 A 10b 170MSs CMOS Pipelined ADC Featuring 84dB SFDR without Calibration.pdf
2008-07-21  18:56           374,870 A 10b 200MSs pipelined folding ADC with offset calibration.pdf
2008-07-21  19:47         2,788,668 A 10b 205MSs 1mm2 90nm CMOS Pipeline ADC for Flat-Panel Display Applications.pdf
2008-07-21  20:12           178,741 A 10MSs 11-b 0.19mm Algorithmic ADC with Improved Clocking.pdf
2008-07-21  11:49         4,828,661 A 12-bit Multi-Channel Non-Calibrating Dual-Mode Successive Approximation ADC for Power Management Bus (PMBus) Devices.pdf
2008-07-21  19:09         1,494,378 A 14-b 30MSs 0.75mm2 Pipelined ADC with On-Chip Digital Self-Calibration.pdf
2008-07-21  19:19           853,056 A 14-bit 100-MSs digitally calibrated binary-weighted current-steering CMOS DAC without calibration ADC.pdf
2008-07-21  13:50         1,492,954 A 14b 100MSs Pipelined ADC with a Merged Active SH and First MDAC.pdf
2008-07-21  19:50         2,531,159 A 14b 40MSs Redundant SAR ADC with 480MHz Clock in 0.13pm CMOS.pdf
2008-07-21  20:20           384,092 A 15b-Linear, 20MSs, 1.5b Stage Pipelined ADC Digitally Calibrated with Signal-Dependent Dithering.pdf
2008-07-21  11:44           603,605 A 1GHz bandwidth low-pass ΔΣ ADC with 20GHz to 50GHz adjustable sampling rate.pdf
2008-07-21  19:04           563,771 A 1V 10b 30MSPS Switched-RC Pipelined ADC.pdf
2008-07-21  19:29           204,656 A 1V 10b 60MSs Hybrid Opamp-Reset Switched-RC pipelined ADC.pdf
2008-07-21  13:34         1,716,071 A 1V 11b 200MSs Pipelined ADC with Digital Background Calibration in 65nm CMOS.pdf
2008-07-21  19:42         4,441,689 A 1V 5-Bit 5GSample sec CMOS ADC for UWB Receivers.pdf
2008-07-21  13:44         2,033,693 A 2.2mW 5b 1.75GSs Folding Flash ADC in 90nm Digital CMOS.pdf
2008-07-21  13:38         2,944,061 A 24GSs 6b ADC in 90nm CMOS.pdf
2008-07-21  13:38         1,765,596 A 32mW 1.25GSs 6b 2b step SAR ADC in 0.13?m CMOS.pdf
2008-07-21  13:39         1,765,596 A 32mW 1.25GSs 6b 2b step SAR ADC.pdf
2008-07-21  11:37         2,947,584 A 4-bit 1.356 Gsps ADC Using Current Processing Method.pdf
2008-07-21  19:48           193,070 A 4.7mW 0.32mm2 10b 30MSs Pipelined ADC Without a Front-End SH in 90nm CMOS.pdf
2008-07-21  19:03         4,399,432 A 43mW Single-Channel 4GSs 4-Bit Flash ADC in 0.18 CMOS.pdf
2008-07-21  18:58           404,076 A 5-bit 1 Gsamples two-stage ADC with a new flash folded architecture.pdf
2008-07-21  19:10           555,350 A 5-bit 4.2-GSs Flash ADC in 0.13m CMOS.pdf
2008-07-21  20:19           220,237 A 500MSs 5b ADC in 65nm CMOS.pdf
2008-07-21  13:18         1,334,202 A 52mW 0.56mm2 1.2V 12b 120MSs SHA-Free dual-channel Nyquist ADC based on mid-code calibration.pdf
2008-07-21  19:06         1,014,693 A 57dB SFDR Digitally Calibrated 500MSs Folding ADC in 0.18m digital CMOS.pdf
2008-07-21  19:23           189,980 A 57mW 10-bit 80-MSs pipeline ADC adopting improved power optimization approach.pdf
2008-07-21  20:14         4,001,739 A 6-bit 1.6 GSs Flash ADC in 0.18-?m CMOS with Reversed-Reference Dummy.pdf
2008-07-21  19:39         2,768,567 A 6-bit 3.5-GSs 0.9-V 98-mW Flash ADC in 90nm CMOS.pdf
2008-07-21  13:25           462,902 A 640MHz CMOS Switched-Capacitor Sigma-Delta ADC with 12 Bits of Resolution by Using Double Sampling Technique.pdf
2008-07-21  13:32         1,791,959 A 6b 0.2-to-0.9V Highly Digital Flash ADC with Comparator Redundancy.pdf
2008-07-21  13:12           627,119 A 7-BIT 400MSs sub-ranging flash ADC in 0.18um CMOS.pdf
2008-07-21  20:22         1,844,020 A 75MSs Low Power Pipeline ADC with scalable Resolution.pdf
2008-07-21  20:19           422,007 A 7bit 800Msps 120mW Folding and Interpolation ADC Using a Mixed-Averaging Scheme.pdf
2008-07-21  19:30           159,273 A 8-bit 125-MSamples pipelined ADC.pdf
2008-07-21  17:58         4,407,294 A 8-bit 14OMSs Pipelined ADC Using Folded Sample-and-Hold Stage.pdf
2008-07-21  20:08         2,835,867 A 92.5mW 205MSs 10b Pipeline IF ADC Implemented in 1.2V 3.3V 0.13 CMOS.pdf
2008-07-21  19:36         2,298,779 A 9Onm CMOS 0.28mm2 1V 12b 40MS s ADC with 0.39pJ Conversion-Step.pdf
2008-07-21  19:24           395,426 A calibration architecture for improving the performance of time-interleaved ADC.pdf
2008-07-21  13:25           234,519 A comprehensive calibration scheme for a 14-b 50 MSPS pipeline ADC for multi-mode wireless receivers.pdf
2008-07-21  13:41         1,516,776 A Continuous Time ?? ADC for Voice Coding with 92dB DR in 45nm CMOS.pdf
2008-07-21  13:41         1,516,776 A Continuous Time.pdf
2008-07-21  19:29           385,421 A Design of 14-bits ADC and DAC for CODEC Applications in 0.18 CMOS process.pdf
2008-07-21  11:43         3,615,808 A Dual-Channel 6b 1GSs 0.18um CMOS ADC for Ultra Wide-Band Communication Systems.pdf
2008-07-21  13:58           102,800 A fast integrating ADC using precise time-to-digital conversion.pdf
2008-07-21  13:56           574,601 A Fast Two-Stage Sample-and-Hold Amplifier for Pipelined ADC Application.pdf
2008-07-21  13:24           267,912 A Feasibility Study on Frequency Domain ADC for Impulse-UWB Receivers.pdf
2008-07-21  13:23           209,023 A fully digital ADC using a new delay element with enhanced linearity.pdf
2008-07-21  18:54           384,312 A high bandwidth power scaleable sub-sampling 10-bit pipelined ADC with embedded sample and hold.pdf
2008-07-21  13:55           329,447 A Low Energy Two-Step Successive Approximation Algorithm for ADC Design.pdf
2008-07-21  20:06           655,163 A Low Power 4-bit Interleaved Burst Sampling ADC for Sub-GHz Impulse UWB Radio.pdf
2008-07-21  11:46         3,940,402 A Low-Cost CMOS Integrated Dual-Mode Dual-Slope ADC with Synchronous Rectification Circuit for AC DC Signal Measuring.pdf
2008-07-21  11:41         3,216,310 A Low-power 7-b 33-Msamples s Switched-current Pipelined ADC for Motor Control.pdf
2008-07-21  20:10           268,908 A Low-Power High-Speed 4-Bit ADC for DS-UWB Communications.pdf
2008-07-21  13:24           733,702 A nanowatt successive approximation ADC with a calibrated capacitor array for biomedical applications.pdf
2008-07-21  11:51         1,879,122 A New Calibration Method for Sampling Clock Skew in Time-interleaved ADC.pdf
2008-07-21  18:03         4,701,555 A New Low Power Flash ADC Using Multiple-Selection Method.pdf
2008-07-21  13:43         2,297,167 A Noise-Coupled Time-Interleaved.pdf
2008-07-21  18:58           175,262 A non linear ADC for sensor linearization.pdf
2008-07-21  11:39         3,112,361 A Novel Method for Systematic Error Prediction of CMOS Folding and Interpolating ADC.pdf
2008-07-21  13:19           228,629 A power scalable 6-bit 1.2GSs flash ADC with power onoff Track-and-Hold and preamplifier.pdf
2008-07-21  19:12           893,006 A Re-configurable 0.5V to 1.2V, 10MSs to 100MSs, Low-Power 10b 0.13um CMOS Pipeline ADC.pdf
2008-07-21  18:59           667,501 A Sample-Time Error Compensation Technique for Time-Interleaved ADC Systems.pdf
2008-07-21  18:53         1,133,944 A simple CMOS-based algorithmic ADC.pdf
2008-07-21  13:34         1,644,815 A Split-Load Interpolation-Amplifier-Array 300MSs 8b Subranging ADC in 90nm CMOS.pdf
2008-07-21  19:51           613,519 A Zero-Crossing-Based 8b 200MSs Pipelined ADC.pdf
2008-07-21  13:26           693,578 An 8-bit 10 kSs 0.18 μm CMOS SAR ADC for RFID applications with sensing capabilities.pdf
2008-07-21  20:03           226,019 An 8-bit 300MSs Switched-Current Pipeline ADC in 0.18 CMOS.pdf
2008-07-21  20:04           190,759 An 8-bit Switched-Resistor Pipeline ADC.pdf
2008-07-21  13:11           512,590 An efficient power reduction technique for flash ADC.pdf
2008-07-21  13:25           656,903 An Elaborate Design and Implementation of a 3rd order Sigma-Delta Modulator ADC for Wideband Signals.pdf
2008-07-21  19:45         2,785,298 An lib 800MS s Time-Interleaved ADC with Digital Background Calibration.pdf
2008-07-21  20:11         1,937,868 An Ultra Low Power Successive Approximation ADC with Selectable Resolution in 0.13 CMOS Technology.pdf
2008-07-21  18:59           255,529 Application of a switch-type comparator in 4-b flash ADC.pdf
2008-07-21  13:29           370,507 Behavioral Modeling of a Programmable UWB Bluetooth ADC.pdf
2008-07-21  13:21           568,103 Capacitive-SAR ADC input offset reduction by stray capacitance compensation.pdf
2008-07-21  11:35         1,007,447 Comparative analysis of two operational amplifier topologies for a 40MSs 12-bit pipelined ADC in 0.35μm CMOS.pdf
2008-07-21  19:51           317,169 Design and Analysis of a High-speed Comparator in a Pipelined ADC.pdf
2008-07-21  13:56           505,609 Design and implementation of a high speed low power 4-bit Flash ADC.pdf
2008-07-21  13:28           657,861 Design of A 7-bit, 200MSs, 2mW pipelined ADC with switched open-loop amplifiers in a 65nm CMOS technology.pdf
2008-07-21  13:54         2,081,992 Highly Interleaved 5b 250MSs ADC with Redundant Channels in 65nm CMOS.pdf
2008-07-21  20:03           393,845 Improved Background Algorithms for Pipeline ADC Full Calibration.pdf
2008-07-21  19:25           221,317 Improved digital calibration technology in a 12-b, 40-MSs pipelined ADC.pdf
2008-07-21  18:54           524,006 Improved power scaling issue for pipeline ADC.pdf
2008-07-21  11:43           471,691 Low Power High Performance Digitally Assisted Pipelined ADC.pdf
2008-07-21  19:27           195,747 Low power high speed switched current comparators for current mode ADC.pdf
2008-07-21  13:20           159,344 Low-power 6-bit 1-GSs two-channel pipeline ADC with open-loop amplification using amplifiers with local-feedback.pdf
2008-07-21  19:07           549,644 Low-Power and High-Speed Pipelined ADC Using Time-Aligned CDS Technique.pdf
2008-07-21  19:24           135,967 Low-power CMOS folding and interpolating ADC with a fully-folding technique.pdf
2008-07-21  20:12           157,678 Low-Power CMOS Fully-Folding ADC with a Novel Bit Synchronization Architecture.pdf
2008-07-21  20:05           947,940 On-Line Histogram Equalization for Flash ADC.pdf
2008-07-21  13:31           508,814 Optimization of pipelined ADC architecture for Monolithic Active Pixel Sensors.pdf
2008-07-21  13:20           294,271 Power-and-area efficient 14-bit 1.5 MSamples two-stage algorithmic ADC based on a mismatch-insensitive MDAC.pdf
2008-07-21  19:31           655,955 Research on High Speed Predictor of Adaptive ADC.pdf
2008-07-21  13:58           343,257 Research on the Low Power Dissipation of Pipeline ADC.pdf
2008-07-21  11:45         1,445,630 System and Circuit Level Design and Analysis of a 16-Bit Sigma-Delta ADC for a TETRA-2 Network Mobile Station Application.pdf
2008-07-21  20:10           381,282 Systematic Design of a Flash ADC for UWB Applications.pdf
2008-07-21  19:40         1,127,121 Timing Error Calibration in Time-Interleaved ADC by Sampling Clock Phase Adjustment.pdf
 楼主| 发表于 2008-11-27 19:17:11 | 显示全部楼层
part 1 of 21
ADC.part01.rar
4.88 MB, 下载次数: 369 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 19:19:46 | 显示全部楼层
part 2 of 21
ADC.part02.rar
4.88 MB, 下载次数: 346 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 19:26:28 | 显示全部楼层
part 3 of 21
ADC.part03.rar
4.88 MB, 下载次数: 289 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 19:44:22 | 显示全部楼层
part 4 of 21
ADC.part04.rar
4.88 MB, 下载次数: 315 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 19:58:48 | 显示全部楼层
part 5 of 21
ADC.part05.rar
4.88 MB, 下载次数: 292 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 20:14:54 | 显示全部楼层
part 6 of 21
ADC.part06.rar
4.88 MB, 下载次数: 288 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 20:35:32 | 显示全部楼层
part 8 of 21
ADC.part08.rar
4.88 MB, 下载次数: 296 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 20:38:41 | 显示全部楼层
part 7 of 21
ADC.part07.rar
4.88 MB, 下载次数: 285 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-11-27 20:50:39 | 显示全部楼层
part 9 of 21
ADC.part09.rar
4.88 MB, 下载次数: 303 , 下载积分: 资产 -3 信元, 下载支出 3 信元
GMT+8, 2025-12-21 19:11 , Processed in 0.028239 second(s), 6 queries , Gzip On, Redis On.
