查看: 22587|回复: 14
请问什么是比导通电阻?
发表于 2008-11-18 16:57:12 | 显示全部楼层 |阅读模式
如题,请教一下。
 楼主| 发表于 2008-11-18 17:01:35 | 显示全部楼层
顶起来~~
发表于 2008-11-19 12:43:14 | 显示全部楼层
有无上下文??
问的要明明白白。。。。
 楼主| 发表于 2008-11-19 22:12:45 | 显示全部楼层
发表于 2009-3-26 16:54:31 | 显示全部楼层
比如说一个LDMOS的比导通电阻是怎么计算的。
发表于 2009-3-27 06:26:27 | 显示全部楼层
Can you say it in English?
发表于 2009-3-27 09:53:52 | 显示全部楼层
How to calculate the specific of HV DMOS, The unit of which is ohm.cm2?
Thanks for you help!
发表于 2009-3-28 09:11:42 | 显示全部楼层
1. By definition Rsp= Rau * L /A
2. Rsp= Rdson x transistor active area. E.g. HV LDMOS's Rdson=2 Ohm,  active area = 1e-3 cm^2. Then your Rsp = 2 mOhm * cm^2.
3. Usually, if current density (Id=A/cm^2) is specified, you can use Rsp* Id to calculate the voltage drop.
Hopefully it helps
发表于 2009-3-28 09:27:38 | 显示全部楼层
纯支持
楼主ID好熟啊,是不是在天涯混的?
-----------------------签名档----------------------------------------
淘宝网女装
发表于 2012-7-26 23:07:35 | 显示全部楼层
回复 8# prof3
Hopefully it helps
    hello ,in your answer,the "active area" is stand for (W*L) or  (W*L+S/D  area) ,thanks!
GMT+8, 2025-12-19 13:16 , Processed in 0.021109 second(s), 6 queries , Gzip On, Redis On.
