查看: 14833|回复: 31
全数字锁相环的verilog源代码
发表于 2008-10-23 10:30:31 | 显示全部楼层 |阅读模式
全数字锁相环的verilog源代码
module dpll(reset,clk,signal_in,signal_out,syn);
parameter para_K=4;
parameter para_N=16;
input reset;
input clk;
input signal_in;
output signal_out;
output syn;
reg signal_out;
reg dpout;
reg delclk;
reg addclk;
reg add_del_clkout;
reg [7:0]up_down_cnt;
reg [2:0]cnt8;
reg [8:0]cnt_N;
reg syn;
reg dpout_delay;
reg [8:0]cnt_dpout_high;
reg [8:0]cnt_dpout_low;
/******phase detector*****/
[email=always@(signal_in]always@(signal_in[/email] or signal_out)
  begin
    dpout<=signal_in^signal_out;
  end
/******synchronization establish detector*****/
[email=always@(posedge]always@(posedge[/email] clk or negedge reset)
  begin
        if(!reset)    dpout_delay<='b0;
        else          dpout_delay<=dpout;
  end
  begin
      if(!reset)
          begin
            cnt_dpout_high<='b0; cnt_dpout_low<='b0;
          end
      else if(dpout)
                if(dpout_delay==0)  cnt_dpout_high<='b0;
                else
                    if(cnt_dpout_high==8'b11111111)  cnt_dpout_high<='b0;
                    else  cnt_dpout_high<=cnt_dpout_high+1;
      else if(!dpout)
                 if(dpout_delay==1)  cnt_dpout_low<='b0;
                 else
                     if(cnt_dpout_low==8'b11111111)  cnt_dpout_low<='b0;
                     else  cnt_dpout_low<=cnt_dpout_low+1;
   end
  begin
          if(!reset)  syn<='b0;
      else if((dpout&&!dpout_delay)||(!dpout&&dpout_delay))
           if(cnt_dpout_high[8:0]-cnt_dpout_low[8:0]<=4||cnt_dpout_low[8:0]-cnt_dpout_high[8:0]<=4)  syn<='b1;
           else  syn<='b0;
  end
/****up down couter with mod=K****/
begin
   if(!reset)
    begin
       delclk<='b0;
       addclk<='b0;
       up_down_cnt<='b00000000;
    end
   else
    begin
      if(!dpout)
       begin
        delclk<='b0;
        if(up_down_cnt==para_K-1)
          begin
            addclk<='b0;
          end
     else
        begin
           up_down_cnt<=up_down_cnt+1;
           addclk<='b0;
        end
      end
else
  begin
  addclk<='b0;
           if(up_down_cnt=='b0)
             begin
               up_down_cnt<=para_K-1;
               delclk<='b0;
             end
            else
             if(up_down_cnt==1)
               begin
                 delclk<='b1;
                 up_down_cnt<=up_down_cnt-1;
               end
             else
             end
          end
  end
/******add and delete clk*****/
begin
  if(!reset)
     begin
       cnt8<='b000;
     end
  else
     begin
      if(cnt8=='b111)
     begin
      cnt8<='b000;
   end
else
    if(addclk&&!syn)
       begin
         cnt8<=cnt8+2;
       end
    else
       if(delclk&&!syn)
          cnt8<=cnt8;
       else
          cnt8<=cnt8+1;
  end
end
[email=always@(cnt8]always@(cnt8[/email] or reset)
begin
if(!reset)
  add_del_clkout<='b0;
else
  add_del_clkout<=cnt8[2];
end
/******counter with mod=N******/
[email=always@(posedge]always@(posedge[/email] add_del_clkout or negedge reset)
begin
  if(!reset)
   begin
    cnt_N<='b0000;
    signal_out<='b0;
   end
else
   begin
     if(cnt_N==para_N-1)
       begin
         cnt_N<='b0000;
         signal_out<='b0;
   end
else
   if(cnt_N==(para_N-1)/2)
     begin
       signal_out<='b1;
       cnt_N<=cnt_N+1;
  end
else
      cnt_N<=cnt_N+1;
  end
end
endmodule
   DPLL由  鉴相器  模K加减计数器  脉冲加减电路  同步建立侦察电路 模N分频器 构成.
整个系统的中心频率(即signal_in和signal_out的码速率的2倍)
为clk/8/N.  模K加减计数器的K值决定DPLL的精度和同步建立时间,K越大,则同步建立时间长,同步精度高.反之则短,低.
发表于 2009-1-14 16:03:42 | 显示全部楼层
ding a  a
发表于 2009-1-31 03:47:24 | 显示全部楼层
好书,赞楼主,多谢
好书,赞楼主,多谢
发表于 2010-5-12 17:12:41 | 显示全部楼层
好同志啊,谢谢
发表于 2010-6-1 10:21:09 | 显示全部楼层
good thanks
发表于 2010-6-1 10:28:40 | 显示全部楼层
goo thanks
发表于 2012-4-25 23:54:41 | 显示全部楼层
GOOD !
发表于 2012-4-26 14:38:20 | 显示全部楼层
学习。学习
发表于 2012-12-13 12:39:02 | 显示全部楼层
谢谢楼主!
发表于 2012-12-19 00:56:15 | 显示全部楼层
THX~~~~~~~~~
GMT+8, 2025-12-9 12:20 , Processed in 0.022383 second(s), 5 queries , Gzip On, Redis On.
